Eclipse Community ForumsPlugin udpate doesn't work
https://www.eclipse.org/forums/index.php/mv/msg/190298/603656/#msg_603656
I developped 2 plugins wich are inside a feature. I created an update site and insert and build my feature. From an other instance of Eclipse, I try to install my plugins from update site but it doesn't work : feature is found but cannot be install because of a "missing" dependency :
Cannot complete the install because one or more required items could not be found.
Missing requirement: 1259335873546 0.0.0.1259335873546 requires 'jm2.plugin.feature.feature.group [5.0.0]' but it could not be found
Feature version is 5.0.0
Plugins versions are the same : 5.0.0
In the folder containing the update site I have these files :
