Eclipse Community Forumsorg.osgi.framework.BundleException: The activator "my plugin" is invalid
https://www.eclipse.org/forums/index.php/mv/msg/188607/598301/#msg_598301
I created an eclipse plugin. I usually test the plugin by running it as a
run-time workbench and it works fine in the runtime workbench.
After I am sure that the plugin works, I exported the plugin as Deployable
plugin and put it in eclipse plugins' directory. The menus and options all
showed up when I load eclipse. However, when I try to run it, there was an
error popup saying that the class needed is not found. When I check the
log file, it gives me the exception : "org.osgi.framework.BundleException:
The activator "my plugin" is invalid"
anybody knows what's happening?
Thanks in advance,
Erwin]]>Erwin2005-01-26T21:45:35-00:00
