Eclipse Community Forumsproblems loading xml schema with targetNamespace
https://www.eclipse.org/forums/index.php/mv/msg/188184/596995/#msg_596995
I would like would like to load an XML model with a XML schema which is
defined
below. I am using Eclipse 3.1 and EMF 2.1 (I am not using RSA anymore)
So, without defining a targetNamespace in the XML schema it works fine.
But with the mentioned targetNamespace "http://www.com.mydb/db" I get a
PackageNotFoundException which is displayed at the bottom...
I guess this comes from the logical URI of the targetNamespace, which
Parser hasn`t the physical URI for, right?
IŽve read something about a URIConverter, which you can use for mapping
logical URIs tu physical URIs.
So IŽve tried the following Java Code:
Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap( ).
put("*", new DbResourceFactoryImpl());
ResourceSet resourceSet = new ResourceSetImpl();
URI uri =
URI.createURI("file:/C:/eclipse/workspace/DbPlugin/samples/load/db.xml ");
I still get the same exception. What still I need to do?
Thanks in advance.
*** THE EXCEPTION:
Exception in thread "main" Wrapped exception
org.eclipse.emf.ecore.xmi.PackageNotFoundException: Package with uri
'null' not found.
(file:/C:/eclipse/workspace/DbPlugin/samples/load/db.xml, 2, 23)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectByType (XMLHandler.java:724)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.createTopObject(XM LHandler.java:765)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.processElement(XML Handler.java:462)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa ndler.java:449)
at
org.eclipse.emf.ecore.xmi.impl.SAXWrapper.startElement(SAXWr apper.java:73)
at org.apache.xerces.parsers.AbstractSAXParser.startElement(Unk nown
Source)
at org.apache.xerces.impl.dtd.XMLDTDValidator.startElement(Unkn own Source)
at
org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanSt artElement(Unknown
Source)
at
org.apache.xerces.impl.XMLDocumentScannerImpl$ContentDispatc her.scanRootElementHook(Unknown
Source)
at
org.apache.xerces.impl.XMLDocumentFragmentScannerImpl$Fragme ntContentDispatcher.dispatch(Unknown
Source)
at
org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanDo cument(Unknown
Source)
at org.apache.xerces.parsers.XML11Configuration.parse(Unknown Source)
at org.apache.xerces.parsers.XMLParser.parse(Unknown Source)
at org.apache.xerces.parsers.AbstractSAXParser.parse(Unknown Source)
at javax.xml.parsers.SAXParser.parse(Unknown Source)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl. java:140)
at
org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLRes ourceImpl.java:169)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:988)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:832)
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo ad(ResourceSetImpl.java:249)
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:264)
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetImpl.java:349)
at app.Main.main(Main.java:31)
Wrapped by
Wrapped exception
'null' not found.
at
at
at
at
at
Source)
at
Source)
at
Source)
at
Source)
at
Source)
at
at
at
at
at
at
Wrapped by
org.eclipse.emf.common.util.WrappedException: Package with uri 'null' not
found. (file:/C:/eclipse/workspace/DbPlugin/samples/load/db.xml, 2, 23)
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:268)
at
at app.Main.main(Main.java:31)]]>Enrique2005-10-19T08:37:50-00:00
