Eclipse Community ForumsHow to view tables, stored procedure etc in DTP
https://www.eclipse.org/forums/index.php/mv/msg/188068/596574/#msg_596574
I have installed eclipse galileo 3.5 for j2ee. I have installed and configure mysql database in eclipse too. I pinged the database and connected successfuly.
I can create database and create tables etc in sql scrapbook, but in database development prespective when go under the schemas then try to expand the folders for tables, user defined function, procedures etc found nothing.I can't see the tables I created under table folder.
I have took the screen shot and uploaded - Where you can see i can't expand the nodes of folder, procedure etc to see my tables etc.
Please tell me what I am doing wrong or missing some thing.
Thanks]]>No real name2009-10-07T10:15:31-00:00Re: How to view tables, stored procedure etc in DTP
https://www.eclipse.org/forums/index.php/mv/msg/188068/596580/#msg_596580
(i.e. generic JDBC, or something else), and what JDBC driver you're using?
--Fitz
virkjay@hotmail.co.uk wrote:
> Hi Guys,
> Thanks]]>Brian Fitzpatrick2009-10-07T19:03:43-00:00Re: How to view tables, stored procedure etc in DTP
https://www.eclipse.org/forums/index.php/mv/msg/188068/596612/#msg_596612
I am using Mysql 5.1 and plugin with Connector J with following jar file - mysql-connector-java 5.1.10 bin.jar.
Driver type used is - MySQL JDBC Driver 5.1
I had gone into (eclipse) window - prefrence, under driver definition added the Mysqljdbc driver 5.1 and mysql-connector-java 5.1.10 bin.jar.
Under database development added new connection configure the connection and connect it and pinged successful but tables are not showing.
Please tell me where I am going wrong or what to do this work properly.
