Eclipse Community ForumsGenerating a DDL from java
https://www.eclipse.org/forums/index.php/mv/msg/186592/591955/#msg_591955
based on a data-model (tables & columns) that I will be reading from a
file. At this stage I am not sure of the file format that I will use.
Can someone point me to the relevant classes, preferably with some sample
code to give me a head start.
Also, if there is a pre-existing format for the datamodel that is tightly
integrated with the DTP project (e.g. EMF model) in which they can be
saved, with a relevant UI tool for editing the data-model, that would also
be fantastic
As an API user, I found it pretty tricky finding relevant documentation on
the DTP APIs - I realise that most usage of DTP is done through other
Eclipse projects, but I am a little stuck at the moment.
