Eclipse Community ForumsRiena 2.0.0.M5
https://www.eclipse.org/forums/index.php/mv/msg/184238/584640/#msg_584640
a new version of Riena is available. Riena 2.0.0.M5 as part of the M5 milestone in Helios.
We hope we get a hint how to fix or work around it pretty soon.
2.0.0.M5 contains a lot of new features like
- controller testing
- a new visual for error marking
- a new hessian version 3.2.0 (which unfortunatelly requires 3.2.0 on both sides client and server)
- an ImageButton (an image that acts like a button)
- many many improvements in the area of MasterDetail
You find all the details in the New and Noteworthy linked above.
If you have any feedback, let us know.
thanks
christian campo]]>Christian Campo2010-02-02T14:17:58-00:00Re: Riena 2.0.0.M5
https://www.eclipse.org/forums/index.php/mv/msg/184238/584716/#msg_584716
> Hi Rienaers,
> New and Noteworthy can be found here
> http://wiki.eclipse.org/Riena_New_And_Noteworthy#2.0.0.M5
> Links to updatesite and target platform are available here
> http://wiki.eclipse.org/Riena_Getting_started
> We started a migration guide from 1.2. to 2.0 over here
> http://wiki.eclipse.org/Riena_Migrating_to_2.0_from_1.2 . Its still very
> small.
> We noticed an issue with the 2.0.0.M5 Riena update site that only exists
> under Eclipse 3.6M5. There is a bug that tracks this problem
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=301534 .
> thanks
> christian campo
While the problem for Eclipse 3.6M5 is still not fixed, you can install Riena from the Helios 3.6M5 repository. There
you can find Riena and update from there.
