Eclipse Community ForumsLibrary aspectrt.jar with Internet Explorer JVM : compatible or not ?
https://www.eclipse.org/forums/index.php/mv/msg/18366/58833/#msg_58833
Originally posted by: ahugueney.fininfo.fr
I tried and used aspectjrt.jar (eclipse 3.1) with Internet Explorer JVM
(5.0.0.3810 / XP sp2). But it failed with a very simple pointcut (trace).
The same worked with the Sun plug-in (JDK 1.5.0_05).
So I guess that the bytecode produced by the AspectJ tools (built from
17/11/2005) are lacking some important compatibility with Internet Explorer
JVM.
says that it should run. So how could I manage to fix this in someway ?
Thanks a lot in advance,
Antoine Hugueney (Java programmer)]]>2005-11-23T17:44:12-00:00Re: Library aspectrt.jar with Internet Explorer JVM : compatible or not ?
https://www.eclipse.org/forums/index.php/mv/msg/18366/591021/#msg_591021
module - we don't do explicit testing with the JVMs in web browsers but
if it doesn't work then it sounds like a bug.
Andy.
> JVM.
> But the documentation referenced at
> http://www.eclipse.org/aspectj/doc/next/devguide/compatibili ty.html#javaCompatibility
>]]>Andrew Clement2005-11-24T08:25:39-00:00Re: Library aspectrt.jar with Internet Explorer JVM : compatible or not ?
https://www.eclipse.org/forums/index.php/mv/msg/18366/58859/#msg_58859
Originally posted by: clemas.uk.ibm.com
What kind of failure do you see? aspectjrt.jar is a Java 1.1 compliant
Andy.
> JVM.
>]]>2005-11-24T08:25:39-00:00
