Eclipse Community ForumsAspectJ project does not clean-build on library change?
https://www.eclipse.org/forums/index.php/mv/msg/18349/58784/#msg_58784
In Eclipse 3.0, AspectJ project will do a rebuild on library change if
auto-build is enabled. In Eclipse 3.1, a library change does not trigger a
rebuild? It does not rebuild to the same result as with Eclipse 3.0. I
need to click the "clean ..." menu item to trigger a clean-build to clean
all those library related compile error marks.]]>harry sheng2005-11-21T18:52:46-00:00Re: AspectJ project does not clean-build on library change?
https://www.eclipse.org/forums/index.php/mv/msg/18349/591002/#msg_591002
This looks like a bug I just fixed - https://bugs.eclipse.org/bugs/show_bug.cgi?id=91420 It should work in
the latest development builds of AJDT.
Sian
harry sheng wrote:
> Just curious.
> a rebuild? It does not rebuild to the same result as with Eclipse 3.0. I
> clean all those library related compile error marks.
>]]>Sian January2005-11-22T14:52:01-00:00Re: AspectJ project does not clean-build on library change?
https://www.eclipse.org/forums/index.php/mv/msg/18349/58809/#msg_58809
This looks like a bug I just fixed - https://bugs.eclipse.org/bugs/show_bug.cgi?id=91420. It should work in
Sian
harry sheng wrote:
> Just curious.
