Eclipse Community ForumsInteresting problem
https://www.eclipse.org/forums/index.php/mv/msg/182930/580186/#msg_580186
I have an ecore model with Process class containing variable class with Variables association name and partnerLink class with partnerLinks association name as shown below.
Now, my problem is how can I specify those relationnames namely partnerLinks and variables into as an Element of XML.
Following ATL code does not help.
rule Process2Root{
from
s : BPEL!Process
to
t : XML!Root(
name <- 'process',
children <- Sequence{xmlns, name, partnerLinks}
xmlns : XML!Attribute(
name <- 'xmlns',
value <- 'http://docs.oasis-open.org/wsbpel/2.0/process/executable'
name <- 'name',
value <- s.name ),
partnerLinks: XML!Element(
name <- 'partnerLinks'
rule prtnerlinks2Elements (
from s: BPEL!PartnerLinks <!-- This is error now as BPEL metamodle does not have PartnerLinks as class -->
How should I work out to make partnerLinks and variables as elemtents that contains partnerlink and variable respectively?
Thanks]]>Transformed2010-08-15T05:09:03-00:00Re: Interesting problem
https://www.eclipse.org/forums/index.php/mv/msg/182930/580202/#msg_580202
If I have understood your problem correctly, the problem is in the From of the second rule.
In this "from" part of your ATL code you should have a class name,
You should use the name of the relation type name and not the relation name.
So you should use:
from s: BPEL!PartnerLink (without the s)
By looking at your code I see a second point:
rule Process2Root{
from
s : BPEL!Process
to
t : XML!Root(
name <- 'process',
name <- 'xmlns',
name <- 'name',
value <- s.name ),
The bold part seems to be incomplete, you should specify that you want the parterlinks of the current process as child of this partnerLinks node. So you should do something like:
name <- 'partnerLinks',
children <- s.partnerLinks
With that the bindings with the PartnerLink elements created from the second rule will be done automatically by ATL.
