Eclipse Community Forumssome small patch ...
https://www.eclipse.org/forums/index.php/mv/msg/182720/579527/#msg_579527
--------------040602020502080004010305
i tried this WE ECF and it looks not so bad :)
I will try it during next week in my company in a development environment.
I did some (diry) hacks on my (anonymous) checked out code, maybe
somebody is interested.
build.xml (from ecf.provider)
I add the environment variable ECLIPSE_HOME and "fixed" some paths, the
HEAD version work only if the workspace is in the eclipse folder (see
bug 85090)
Additionaly i add a manifest and the classes from org.eclipse.ecf
package to the provider.jar (that is the diry part), but with this
changes it is possible to run the server with a simple statment:
java -jar provider.jar
Oh no two small changes was required too.
The Trace.java classes in the packages
org.eclipse.efc.core.intenrnal.core &
org.eclipse.efc.provider
<target name="build.jars" depends="init" description="Build all the jars for the plug-in: org.eclipse.ecf.provider.">
<available property="provider.jar" file="${build.result.folder}/provider.jar"/>
<antcall target="provider.jar"/>
</target>
* Copyright (c) 2004 Composent, Inc. and others.
* All rights reserved. This program and the accompanying materials
* are made available under the terms of the Eclipse Public License v1.0
* which accompanies this distribution, and is available at
* http://www.eclipse.org/legal/epl-v10.html
* Contributors:
* Composent, Inc. - initial API and implementation
public class Trace {
public static final String tracePrefix = "(trace)";
public static boolean ON = false;
protected static boolean isEclipse = false;
protected static String pluginName = "";
protected static String debugPrefix = "/debug/";
static {
try {
//ON = Platform.inDebugMode();
String val = System.getProperty(ProviderPlugin.PROVIDERPLUGIN_ID+".Trace ");
if (val != null) {
setTrace(true);
isEclipse = false;
// No eclipse Platform available
System.out.println("WARNING: Eclipse platform not being use for trace...overridden by system property org.eclipse.ecf.provider.Trace");
} else {
isEclipse = true;
pluginName = ProviderPlugin.PROVIDERPLUGIN_ID;
} catch (Exception e) {
try {
if (val != null) {
setTrace(true);
isEclipse = false;
System.out.println("WARNING: Eclipse platform not available for trace...using system.out for org.eclipse.ecf.provider");
} else {
System.out.println(Trace.class.getName()+": OFF");
} catch (Exception except) {
public static void setTrace(boolean on) {
ON = on;
public static Trace create(String key) {
if (isEclipse) {
String res = ""; //Platform
//.getDebugOption(pluginName + debugPrefix + key);
if (res != null) {
Boolean on = new Boolean(res);
if (on.booleanValue())
return new Trace(pluginName + "(" + key + ")");
else
return null;
} else {
return null;
} else
return new Trace(key);
String name;
public void dumpStack(Throwable e, String msg) {
msg(msg);
e.printStackTrace(System.err);
public void msg(String msg) {
StringBuffer sb = new StringBuffer(name);
sb.append(getTimeString()).append(msg);
System.out.println(sb.toString());
protected static String getTimeString() {
Date d = new Date();
SimpleDateFormat df = new SimpleDateFormat("[MM/dd/yy;HH:mm:ss:SSS]");
return df.format(d);
protected Trace(String str) {
name = tracePrefix+str;
* Contributors:
static {
try {
String val = System.getProperty(ECFPlugin.PLUGIN_ID+".Trace");
if (val != null) {
setTrace(true);
isEclipse = false;
System.out.println("WARNING: Eclipse platform not available for trace...overridden by system property org.eclipse.ecf.Trace");
} else {
isEclipse = true;
pluginName = ECFPlugin.PLUGIN_ID;
try {
if (val != null) {
setTrace(true);
isEclipse = false;
System.out.println("WARNING: Eclipse platform not available for trace...using system.out for org.eclipse.ecf");
} else {
ON = on;
if (isEclipse) {
if (res != null) {
else
return null;
} else {
return null;
} else
String name;
msg(msg);
public static String convertStringAToString(String [] strings) {
if (strings==null) return "";
StringBuffer sb = new StringBuffer();
for(int i=0; i < strings.length; i++) {
if (strings[i]==null) sb.append("(null)");
else sb.append(strings[i]);
if (i != (strings.length-1)) sb.append(";");
return sb.toString();
public static String convertObjectAToString(Object [] objs) {
if (objs==null) return "";
for(int i=0; i < objs.length; i++) {
if (objs[i]==null) sb.append("(null)");
else sb.append(objs[i].toString());
if (i != (objs.length-1)) sb.append(";");
public static void setThreadDebugGroup(Object obj) {
// Do nothing
--------------040602020502080004010305--]]>Stephan Zehrer2005-02-13T21:01:30-00:00Re: some small patch ...
https://www.eclipse.org/forums/index.php/mv/msg/182720/579576/#msg_579576
Stephan Zehrer wrote:
Yes, indeed...thanks for your efforts and reports! Keep them coming if
you can!
> bug 85090)
Yes thanks. Will apply this fix this evening (Sunday).
Thanks. We'll add this so that servers can be more easily launched with
the -jar command.
> I disabeld the platform dependencies.
These calls to Platform.are specifically in there so that the trace code
can run via the Eclipse tracing mechanism. I wanted to have this Trace
class be usable by either the Eclipse tracing mechanism or as a normal
application (i.e. without the Eclipse runtime at all).
So I don't want to remove the Platform import as you did...but I see
that I did put an error in the Trace code that tries to load the
Platform class without another ClassNotFoundException catch later in the
code. I will fix this an check it in this evening as well.
Again THANKS.
Scott
> bye
> Stephan Zehrer
> <project name="org.eclipse.ecf.provider" default="build.jars" basedir=".">
> <property name="bootclasspath" value=""/>
> <property name="basews" value="${ws}"/>
> <property name="baseos" value="${os}"/>
> <property name="basearch" value="${arch}"/>
> <property name="basenl" value="${nl}"/>
> <property name="javacFailOnError" value="false"/>
> <property name="javacDebugInfo" value="on"/>
> <property name="javacVerbose" value="true"/>
> <property name="javacSource" value="1.3"/>
> <property name="javacTarget" value="1.2"/>
> <property name="compilerArg" value=""/>
> <property environment="env"/>
> <target name="init" depends="properties">
> <condition property="pluginTemp" value="${buildTempFolder}/plugins">
> <isset property="buildTempFolder"/>
> </condition>
> <property name="pluginTemp" value="${basedir}"/>
> <condition property="build.result.folder" value="${pluginTemp}/org.eclipse.ecf.provider">
> </condition>
> <property name="build.result.folder" value="${basedir}"/>
> <property name="temp.folder" value="${basedir}/temp.folder"/>
> <property name="plugin.destination" value="${basedir}"/>
> <property name="eclipse.home" value="${env.ECLIPSE_HOME}"/>
> </target>
> <target name="properties" if="eclipse.running">
> <property name="build.compiler" value="org.eclipse.jdt.core.JDTCompilerAdapter"/>
> </target>
> <target name="build.update.jar" depends="init" description="Build the plug-in: org.eclipse.ecf.provider for an update site.">
> <delete dir="${temp.folder}"/>
> <mkdir dir="${temp.folder}"/>
> <antcall target="build.jars"/>
> <antcall target="gather.bin.parts">
> <param name="destination.temp.folder" value="${temp.folder}/"/>
> </antcall>
> <zip zipfile="${plugin.destination}/org.eclipse.ecf.provider_1.0.0.jar " basedir="${temp.folder}/org.eclipse.ecf.provider_1.0.0" filesonly="false" whenempty="skip" update="false"/>
> </target>
> <target name="provider.jar" depends="init" unless="provider.jar" description="Create jar: provider.jar.">
> <delete dir="${temp.folder}/provider.jar.bin"/>
> <mkdir dir="${temp.folder}/provider.jar.bin"/>
> <!-- compile the source code -->
> <javac destdir="${temp.folder}/provider.jar.bin" failonerror="${javacFailOnError}" verbose="${javacVerbose}" debug="${javacDebugInfo}" includeAntRuntime="no" bootclasspath="${bootclasspath}" source="${javacSource}" target="${javacTarget}" >
> <compilerarg line="${compilerArg}"/>
> <classpath>
> <pathelement path=" ${eclipse.home}/plugins/org.eclipse.core.runtime_3.1.0/eclip se3.1m4/eclipse/plugins/org.eclipse.core.runtime_3.1.0/runti me.jar "/>
> <pathelement path=" ${eclipse.home}/plugins/org.eclipse.core.runtime_3.1.0/runti me.jar "/>
> <pathelement path=" ${eclipse.home}/plugins/org.eclipse.osgi_3.1.0/eclipse3.1m4/ eclipse/plugins/org.eclipse.osgi_3.1.0/osgi.jar "/>
> <pathelement path=" ${eclipse.home}/plugins/org.eclipse.osgi_3.1.0/eclipse3.1m4/ eclipse/plugins/org.eclipse.osgi_3.1.0/core.jar "/>
> <pathelement path=" ${eclipse.home}/plugins/org.eclipse.osgi_3.1.0/eclipse3.1m4/ eclipse/plugins/org.eclipse.osgi_3.1.0/resolver.jar "/>
> <pathelement path=" ${eclipse.home}/plugins/org.eclipse.osgi_3.1.0/eclipse3.1m4/ eclipse/plugins/org.eclipse.osgi_3.1.0/defaultAdaptor.jar "/>
> <pathelement path=" ${eclipse.home}/plugins/org.eclipse.osgi_3.1.0/eclipse3.1m4/ eclipse/plugins/org.eclipse.osgi_3.1.0/eclipseAdaptor.jar "/>
> <pathelement path=" ${eclipse.home}/plugins/org.eclipse.osgi_3.1.0/eclipse3.1m4/ eclipse/plugins/org.eclipse.osgi_3.1.0/console.jar "/>
> <pathelement path="${eclipse.home}/plugins/org.eclipse.osgi_3.1.0/core.jar "/>
> <pathelement path="${eclipse.home}/plugins/org.eclipse.osgi_3.1.0/console.jar "/>
> <pathelement path="${eclipse.home}/plugins/org.eclipse.osgi_3.1.0/osgi.jar "/>
> <pathelement path="${eclipse.home}/plugins/org.eclipse.osgi_3.1.0/resolver.jar "/>
> <pathelement path=" ${eclipse.home}/plugins/org.eclipse.osgi_3.1.0/defaultAdapto r.jar "/>
> <pathelement path=" ${eclipse.home}/plugins/org.eclipse.osgi_3.1.0/eclipseAdapto r.jar "/>
> <pathelement path="../org.eclipse.ecf/bin"/>
> <pathelement path="../org.eclipse.ecf/ecf.jar"/>
> <pathelement path="@dot"/>
> </classpath>
> <src path="src/" />
> </javac>
> <!-- Copy necessary resources -->
> <copy todir="${temp.folder}/provider.jar.bin" failonerror="true">
> <fileset dir="src/" excludes="**/*.java, **/package.htm*" />
> </copy>
> <mkdir dir="${build.result.folder}"/>
> <jar jarfile="${build.result.folder}/provider.jar">
> <fileset dir="${temp.folder}/provider.jar.bin"/>
> <fileset dir="../org.eclipse.ecf/bin"/>
> <manifest>
> <attribute name="Main-Class" value="org.eclipse.ecf.provider.app.ServerApplication"/>
> </manifest>
> </jar>
> </target>
> <target name="providersrc.zip" depends="init" unless="providersrc.zip">
> <zip zipfile="${build.result.folder}/providersrc.zip" filesonly="false" whenempty="skip" update="false">
> <fileset dir="src/" includes="**/*.java" />
> </zip>
> </target>
> </target>
> <target name="build.sources" depends="init">
> <available property="providersrc.zip" file="${build.result.folder}/providersrc.zip"/>
> <antcall target="providersrc.zip"/>
> </target>
> <target name="gather.bin.parts" depends="init" if="destination.temp.folder">
> <mkdir dir="${destination.temp.folder}/org.eclipse.ecf.provider_1.0.0 "/>
> <copy todir="${destination.temp.folder}/org.eclipse.ecf.provider_1.0.0 " failonerror="true">
> <fileset dir="${build.result.folder}" includes="provider.jar" />
> </copy>
> <fileset dir="${basedir}" includes="plugin.xml,provider.jar,META-INF/" />
> </copy>
> </target>
> <target name="build.zips" depends="init">
> </target>
> <target name="gather.sources" depends="init" if="destination.temp.folder">
> <copy file="${build.result.folder}/providersrc.zip" todir="${destination.temp.folder}/org.eclipse.ecf.provider_1.0.0 " failonerror="false"/>
> <copy todir="${destination.temp.folder}/org.eclipse.ecf.provider_1.0.0 " failonerror="false">
> <fileset dir="${basedir}" includes="src/,plugin.xml,provider.jar,META-INF/" />
> </copy>
> </target>
> <target name="gather.logs" depends="init" if="destination.temp.folder">
> <copy file="${temp.folder}/provider.jar.bin.log" todir="${destination.temp.folder}/org.eclipse.ecf.provider_1.0.0 " failonerror="false"/>
> </target>
> <target name="clean" depends="init" description="Clean the plug-in: org.eclipse.ecf.provider of all the zips, jars and logs created.">
> <delete file="${build.result.folder}/provider.jar"/>
> <delete file="${build.result.folder}/providersrc.zip"/>
> <delete file="${plugin.destination}/org.eclipse.ecf.provider_1.0.0.jar "/>
> <delete file="${plugin.destination}/org.eclipse.ecf.provider_1.0.0.zip "/>
> </target>
> <target name="refresh" depends="init" if="eclipse.running" description="Refresh this folder.">
> <eclipse.convertPath fileSystemPath="C:/eclipse3.1m4/eclipse/workspace/org.eclipse.ecf.provider " property="resourcePath"/>
> <eclipse.refreshLocal resource="${resourcePath}" depth="infinite"/>
> </target>
> <target name="zip.plugin" depends="init" description="Create a zip containing all the elements for the plug-in: org.eclipse.ecf.provider.">
> <antcall target="build.sources"/>
> </antcall>
> <antcall target="gather.sources">
> </antcall>
> <delete>
> <fileset dir="${temp.folder}" includes="**/*.bin.log" />
> </delete>
> <zip zipfile="${plugin.destination}/org.eclipse.ecf.provider_1.0.0.zip " basedir="${temp.folder}" filesonly="true" whenempty="skip" update="false"/>
> </target>
> </project>
> * Contributors:
> package org.eclipse.ecf.provider;
> import java.text.SimpleDateFormat;
> import java.util.Date;
> //import org.eclipse.core.runtime.Platform;
> static {
> try {
> if (val != null) {
> setTrace(true);
> isEclipse = false;
> } else {
> isEclipse = true;
> try {
> if (val != null) {
> setTrace(true);
> isEclipse = false;
> } else {
> ON = on;
> if (isEclipse) {
> if (res != null) {
> else
> return null;
> } else {
> return null;
> } else
> String name;
> msg(msg);
> * Contributors:
> package org.eclipse.ecf.internal.core;
> static {
> try {
> if (val != null) {
> setTrace(true);
> isEclipse = false;
> } else {
> isEclipse = true;
> try {
> if (val != null) {
> setTrace(true);
> isEclipse = false;
> } else {
> ON = on;
> if (isEclipse) {
> if (res != null) {
> else
> return null;
> } else {
> return null;
> } else
> String name;
> msg(msg);
> // Do nothing
> }]]>Scott Lewis2005-02-13T23:36:51-00:00
