Eclipse Community ForumsIs there a step-by-step to install MTJ in Eclipse
https://www.eclipse.org/forums/index.php/mv/msg/182644/579272/#msg_579272
Anyway, I am now taking a class in mobile application development and want to install MTJ in Eclipse and I can't see that it seems that easy and straightforward.
When I go to install I get errors stating that "no repository found containing" a bunch of folders. I've attempted to find the downloads for these folders but don't see any that exactly match this error list. I've found a bunch of jar files that look close but I know there has to be a clearer way here.
Can someone help?
Frank]]>chupalo 2010-01-30T21:45:32-00:00Re: Is there a step-by-step to install MTJ in Eclipse
https://www.eclipse.org/forums/index.php/mv/msg/182644/579311/#msg_579311
if you want to install from yourself, i would suggest that you move to eclipse galileo (3.5). since mtj 1.0.1 it only runs on it (as far as i remember)
after all install is ok, please refer to http://help.eclipse.org/galileo/nav/18 to setup your environment. if you have questions plewase send to the forum
gep]]>Gustavo de Paula2010-02-01T14:15:24-00:00
