Eclipse Community Forumsproblems with voicetools
https://www.eclipse.org/forums/index.php/mv/msg/180445/572439/#msg_572439
Originally posted by: kai.easyconnect.no
Error 2005-08-26 10:36:40.579 Problems occurred when invoking code from
plug-in: "org.eclipse.jface".
Does anybody else have this problem? I cannot seem to get the voicetools
editors to work. This is a fresh install. Anybody out there who know how
to remedy this?
- Kai
java.lang.NoSuchMethodError:
org.eclipse.vtp.editor.ccxml.contentassist.NoRegionContentAs sistProcessorForCCXML.addPartitionProcessor(Ljava/lang/Strin g;Lorg/eclipse/jface/text/contentassist/IContentAssistProces sor;)V
at
org.eclipse.vtp.editor.ccxml.contentassist.NoRegionContentAs sistProcessorForCCXML.initPartitionToProcessorMap(Unknown
Source)
at
org.eclipse.wst.xml.ui.internal.contentassist.NoRegionConten tAssistProcessor. <init>(NoRegionContentAssistProcessor.java:61)
at
org.eclipse.vtp.editor.ccxml.contentassist.NoRegionContentAs sistProcessorForCCXML. <init>(Unknown
Source)
at
org.eclipse.vtp.editor.ccxml.StructuredTextViewerConfigurati onCCXML.createNoRegionContentAssistProcessor(Unknown
Source)
at
org.eclipse.vtp.editor.StructuredTextViewerConfiguration.get ContentAssistant(Unknown
Source)
at
org.eclipse.wst.sse.ui.internal.StructuredTextViewer.configu re(StructuredTextViewer.java:265)
at
org.eclipse.ui.texteditor.AbstractTextEditor.createPartContr ol(AbstractTextEditor.java:2502)
at
org.eclipse.ui.texteditor.StatusTextEditor.createPartControl (StatusTextEditor.java:53)
at
org.eclipse.ui.texteditor.AbstractDecoratedTextEditor.create PartControl(AbstractDecoratedTextEditor.java:303)
at
org.eclipse.wst.sse.ui.internal.StructuredTextEditor.createP artControl(StructuredTextEditor.java:850)
at
org.eclipse.ui.internal.EditorManager.busyRestoreEditorHelpe r(EditorManager.java:1237)
at
org.eclipse.ui.internal.EditorManager.busyRestoreEditor(Edit orManager.java:1102)
at org.eclipse.ui.internal.EditorManager$7.run(EditorManager.ja va:1064)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
at
org.eclipse.ui.internal.EditorManager.restoreEditor(EditorMa nager.java:1062)
at
org.eclipse.ui.internal.EditorManager$Editor.getEditor(Edito rManager.java:1648)
at
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2238)
at
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2165)
at org.eclipse.ui.internal.WorkbenchPage.access$7(WorkbenchPage .java:2157)
at org.eclipse.ui.internal.WorkbenchPage$9.run(WorkbenchPage.ja va:2143)
at
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2138)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:371)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:334)
at org.eclipse.ui.actions.OpenFileAction.openFile(OpenFileActio n.java:98)
at
org.eclipse.ui.actions.OpenSystemEditorAction.run(OpenSystem EditorAction.java:98)
at
org.eclipse.ui.views.navigator.OpenActionGroup.runDefaultAct ion(OpenActionGroup.java:120)
at
org.eclipse.ui.views.navigator.MainActionGroup.runDefaultAct ion(MainActionGroup.java:316)
at
org.eclipse.ui.views.navigator.ResourceNavigator.handleOpen( ResourceNavigator.java:648)
at
org.eclipse.ui.views.navigator.ResourceNavigator$6.open(Reso urceNavigator.java:406)
at
org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredV iewer.java:658)
at
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:1021)
at org.eclipse.core.runtime.Platform.run(Platform.java:757)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:40)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:14 8)
at
org.eclipse.jface.viewers.StructuredViewer.fireOpen(Structur edViewer.java:656)
at
org.eclipse.jface.viewers.StructuredViewer.handleOpen(Struct uredViewer.java:875)
at
org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(Stru cturedViewer.java:974)
at org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrate gy.java:243)
at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.ja va:238)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrate gy.java:277)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:842)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2894)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2527)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1570)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1534)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:306)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:228)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:344)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:156)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:315 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:268)
at org.eclipse.core.launcher.Main.run(Main.java:942)
at org.eclipse.core.launcher.Main.main(Main.java:926)]]>2005-08-26T08:40:52-00:00
