Eclipse Community ForumsTrue Multi Module Support?
https://www.eclipse.org/forums/index.php/mv/msg/180086/571449/#msg_571449
Specifically my questions are:
- Is there multi-module support such that each module can be its own eclipse project and dependencies are properly handled?
- Is there support for things like dependency and plugin management within the parent POM?]]>Chad La Joie2009-12-06T10:13:58-00:00Re: True Multi Module Support?
https://www.eclipse.org/forums/index.php/mv/msg/180086/571519/#msg_571519
> I was wondering if IAM had good multi-module support.
yes, that's the default approach
you can import the parent pom project too and pretty much things will work.
The real issue with multimodule projects and eclipse is the lack of
support at the core for nested projects, a long time feature request in
the Eclipse community
