Eclipse Community ForumsBug located when calling a java class from a transformation
https://www.eclipse.org/forums/index.php/mv/msg/178174/566174/#msg_566174
While creating a wrapper class for MOFScript I detected that when the
java() function is called inside a transformation for a non-static class,
the tool allocates some memory for the instance of the called class which
is never freed!! The Windows process manager shows this memory growth of
the eclipse.exe process.
