Eclipse Community ForumsWSAD 5.0 / ANT 1.5.1 / AJDT 1.1.1
https://www.eclipse.org/forums/index.php/mv/msg/177762/565014/#msg_565014
I am trying to build using the above configuration, but I fail to do so.
The ANT script I use runs perfectly when invoked from the DOS prompt, but
fails when invoked from WSAD.
When run under WSAD, I get
java.lang.NoClassDefFoundError:
org/aspectj/ajdt/internal/core/builder/ClasspathContainer
at org.aspectj.ajdt.ajc.AjdtCommand.runCommand(AjdtCommand.java :50)
at org.aspectj.tools.ajc.Main.run(Main.java:216)
at org.aspectj.tools.ant.taskdefs.Ajc10.spoon(Ajc10.java:598)
at org.aspectj.tools.ant.taskdefs.Ajc10.execute(Ajc10.java:484)
at org.apache.tools.ant.UnknownElement.execute(UnknownElement.j ava:193)
at org.apache.tools.ant.Task.perform(Task.java:341)
at org.apache.tools.ant.Target.execute(Target.java:309)
at org.apache.tools.ant.Target.performTasks(Target.java:336)
at org.apache.tools.ant.Project.executeTarget(Project.java:1339 )
at org.apache.tools.ant.taskdefs.Ant.execute(Ant.java:397)
at org.apache.tools.ant.taskdefs.CallTarget.execute(CallTarget. java:143)
at org.apache.tools.ant.Project.executeTargets(Project.java:125 5)
at
org.eclipse.ant.internal.core.ant.InternalAntRunner.run(Inte rnalAntRunner.java:262)
at org.eclipse.ant.core.AntRunner.run(AntRunner.java:234)
at
org.eclipse.ui.externaltools.internal.core.AntFileRunner.exe cute(AntFileRunner.java:56)
at
org.eclipse.ui.externaltools.internal.core.DefaultRunnerCont ext.executeRunner(DefaultRunnerContext.java:428)
at
org.eclipse.ui.externaltools.internal.core.DefaultRunnerCont ext.run(DefaultRunnerContext.java:479)
at
org.eclipse.ui.externaltools.internal.ui.AntLaunchWizard$1.r un(AntLaunchWizard.java:117)
at
org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext.java:98)
Any clues anybody?]]>Peter Friese2003-03-21T14:25:45-00:00
