Eclipse Community Forums[Epsilon] EGL running the example
https://www.eclipse.org/forums/index.php/mv/msg/174982/557392/#msg_557392
I have some problems to run the EGL Example (org.eclipse.epsilon.examples.egldoc.zip).
I just downloaded the zip file and imported it into a Java Project within Eclipse. But now I have some trouble to solve the import problems.
I added some libraries like
org.eclipse.epsilon.eol.engine.jar
org.eclipse.epsilon.egl.engine.jar
org.eclipse.epsilon.commons.jar
to the build path and changed the imports in the java classes from org.epsilon to org.eclipse.epsilon.
But there is a problem I cannot resolve. In the class EglDocFacade.java (line 69 and 70) I get the following error message
The method getScope() is undefined for the type IEglContext
Have there been any major changes on the interfaces in the last time?
Or do I have to import other libraries to run the example?
Andreas
]]>Andreas2010-09-07T09:27:42-00:00Re: [Epsilon] EGL running the example
https://www.eclipse.org/forums/index.php/mv/msg/174982/557912/#msg_557912
http://www.eclipse.org/forums/index.php?t=msg&th=175068& amp;start=0&S=093e3fc6d59ed4a00c1e003c30afc422]]>Andreas2010-09-09T12:06:57-00:00Re: [Epsilon] EGL running the example
https://www.eclipse.org/forums/index.php/mv/msg/174982/942712/#msg_942712
Duke Payen2012-10-13T20:27:10-00:00
