Eclipse Community ForumsEclipse Automated Tests 3.6
https://www.eclipse.org/forums/index.php/mv/msg/172496/548838/#msg_548838
The solution might well be very obvious, but I can't seem to find the source files for tests in the eclipse-Automated-Tests-3.6.zip. There are only compiled versions in there. I read some post suggesting CVS, but I trawled CVS repositories and couldn't find what I need.
Could someone please give me straightforward directions to getting the source files?]]>No real name2010-07-23T09:15:51-00:00Re: Eclipse Automated Tests 3.6
https://www.eclipse.org/forums/index.php/mv/msg/172496/548887/#msg_548887
be done from the test framework and tests in binary form.
If you really want the source:
1) each team keeps the source in a different location in
/cvsroot/eclipse. some teams have modules (like platform-ui-tests).
2) if you use the source build instructions (included on the 3.6
download page) you will get all of the source checked out from CVS,
including the tests
2) if you load the binary plugins in your target environment, you can
use File>Import...>Plug-in Development>Plug-ins and fragments. Select
the plugins you want, and then import the from a repository (as opposed
to as binary plugins).
All of the 3.6 automated tests have their Eclipse-SourceReferences
header set. That means if you have the tests available to run in your
target platform from eclipse-junit-tests-I20100608-0911.zip, you can use
File>Import...>Plug-in Development>Plug-ins and Fragments in 3.6 and
import the source from the repository.
