Eclipse Community Forums2.2 Plugin not being loaded
https://www.eclipse.org/forums/index.php/mv/msg/172325/548244/#msg_548244
anyedit-2.3.1/
emf-2.6/
gef-3.6/
subclipse-1.6.12/
wtp-3.2/
dltk-2.0/
findbugs-1.3.9/
pdt-2.2.0/
tomcat-3.2.1/
xsd-2.6/
Under the Plugins section in "Eclipse Installation Details" I can see PDT. But I cannot see any PHP options under Preferences. Also, although a project has been marked as PHPNature it does not open the PHP perspective.
What could be the problem? Thanks in advance for any help.]]>Atharva 2010-07-21T08:54:09-00:00Re: 2.2 Plugin not being loaded
https://www.eclipse.org/forums/index.php/mv/msg/172325/548964/#msg_548964
I installed aptana as a plugin into helios, and though it's in the list of installed plugins, I can't find any hint within the gui. Can't see neither a aptana perspective, nor can I use the built in ftp-tool.
I've uninstalled and reinstalled without solving the problem. I downloaded it from within eclipse itself, and even downloaded it and installed it manually. Nothing helps.
Btw, I'm using Windows XP.]]>c.sileo2010-07-23T14:41:57-00:00Re: 2.2 Plugin not being loaded
https://www.eclipse.org/forums/index.php/mv/msg/172325/555747/#msg_555747
]]>c.sileo2010-08-28T07:49:36-00:00
