Eclipse Community Forums[Eugenia] Newbie question. Problems in the generated editor with the Folder Item.
https://www.eclipse.org/forums/index.php/mv/msg/171685/546117/#msg_546117
--------------080301040803050308020009
I have had problems with the annotations which do not have
properties, so I solved the problems creating the foo property, as it is
written in the tutorial(I've read in a previous post that this problem
is due to the emfatic version), so I have written the annotations
@gmf(foo="bar"), and @gmf.diagram(foo="bar"), and
@gmf.compartment(foo="bar").
However, when I follow the whole process to generate the editor, and
I test the generated editor, the item Folder is disabled. That is, I can
not create any folder, and as you can see in the image file I have
attached, there is no icon associated to Folder.
I also have tried to change the Folder annotation to set the default
values of the properties:
class Folder extends File {
@gmf.compartment(layout="free",collapsible="true")
val File[*] contents;
But the problems remains the same, that is, I can not create folders.
Any idea of the problem?
Thanks and regards,
To]]>Toñi Reina2010-07-11T10:06:55-00:00Re: [Eugenia] Newbie question. Problems in the generated editor with the Folder Item.
https://www.eclipse.org/forums/index.php/mv/msg/171685/546119/#msg_546119
Thanks for reporting this. This seems to be a regression introduced in
the latest version of Epsilon. Could you please file a bug report for
this using the link below?
On 11/07/2010 11:06, Toñi Reina Quintero wrote:
> Hi all,
> I just recently heard from Eugenia, and I wanted to test it to see how
> it worked. So I followed the tutorial from
> http://www.eclipse.org/gmt/epsilon/doc/articles/eugenia-gmf- tutorial/
> and the corresponding screencast from
> http://www.eclipse.org/gmt/epsilon/cinema/Eugenia.htm
> I have had problems with the annotations which do not have properties,
> so I solved the problems creating the foo property, as it is written in
> the tutorial(I've read in a previous post that this problem is due to
> the emfatic version), so I have written the annotations @gmf(foo="bar"),
> and @gmf.diagram(foo="bar"), and @gmf.compartment(foo="bar").
> However, when I follow the whole process to generate the editor, and I
> Thanks and regards,
> Toñi
>]]>Dimitrios Kolovos2010-07-11T10:45:34-00:00Re: [Eugenia] Newbie question. Problems in the generated editor with the Folder Item.
https://www.eclipse.org/forums/index.php/mv/msg/171685/590584/#msg_590584
> Hi all,
> Thanks and regards,
> Toñi
https://www.eclipse.org/forums/index.php/mv/msg/171685/590594/#msg_590594
I've fixed this and uploaded a new interim version under http://download.eclipse.org/modeling/gmt/epsilon/interim/
Thanks again for reporting this!
Dimitris
On 11/07/2010 11:45, Dimitris Kolovos wrote:
> Hi Toni,
> https://bugs.eclipse.org/bugs/enter_bug.cgi?product=GMT& component=Epsilon
> Cheers,
> Dimitris
>> Hi all,
>> Thanks and regards,
>> Toñi
>]]>Dimitrios Kolovos2010-07-11T11:51:32-00:00Re: [Eugenia] Newbie question. Problems in the generated editor with the Folder Item.
https://www.eclipse.org/forums/index.php/mv/msg/171685/546121/#msg_546121
Dimitris
> Hi Toni,
> Cheers,
> Dimitris
>> Hi all,
>> Thanks and regards,
>> Toñi
https://www.eclipse.org/forums/index.php/mv/msg/171685/590608/#msg_590608
I'm happy to see that the problem is not due to the way I'm doing things.
As you have fixed the problem. Do you still want me to file the bug report?
Toñi
Dimitris Kolovos escribió:
> Hi Toni,
> Cheers,
> Dimitris
>> Hi Toni,
>> Cheers,
>> Dimitris
>>> Hi all,
>>> Thanks and regards,
>>> Toñi
>]]>Toñi Reina2010-07-11T13:53:50-00:00Re: [Eugenia] Newbie question. Problems in the generated editor with the Folder Item.
https://www.eclipse.org/forums/index.php/mv/msg/171685/546131/#msg_546131
Toñi
> Hi Toni,
> Cheers,
> Dimitris
>> Hi Toni,
>> Cheers,
>> Dimitris
>>> Hi all,
>>> Thanks and regards,
>>> Toñi
https://www.eclipse.org/forums/index.php/mv/msg/171685/590612/#msg_590612
On 11/07/2010 14:53, Toñi Reina Quintero wrote:
> You're wellcome.
Yes please.
> Regards,
> Toñi
Dimitris
>> Hi Toni,
>> Cheers,
>> Dimitris
>>> Hi Toni,
>>> Cheers,
>>> Dimitris
>>>> Hi all,
>>>> @gmf(foo="bar"),
>>>> Thanks and regards,
>>>> Toñi
>>]]>Dimitrios Kolovos2010-07-11T14:00:05-00:00Re: [Eugenia] Newbie question. Problems in the generated editor with the Folder Item.
https://www.eclipse.org/forums/index.php/mv/msg/171685/546132/#msg_546132
> You're wellcome.
Yes please.
> Regards,
> Toñi
Dimitris
>> Hi Toni,
>> Cheers,
>> Dimitris
>>> Hi Toni,
>>> Cheers,
>>> Dimitris
>>>> Hi all,
>>>> @gmf(foo="bar"),
>>>> Thanks and regards,
>>>> Toñi
https://www.eclipse.org/forums/index.php/mv/msg/171685/590624/#msg_590624
--------------060401060207020708040305
Hi Dimitris,
I have reported the bug and tested the new version. Now it works :-)
Just a question more. When I create a Filesystem Diagram in the new
generated editor (it also happened with the old version), an error
attached to the .filesystem_diagram file is reported in the Project
Explorer, saying that there is no label provided for
filesystem.diagram.navigator.FileSystemNavigatorI. You can see the error
in the image file I have attached.
Why is the editor reporting this error? Is there any property that has
not been set in the .emf file?
Thanks again, and regards.
Dimitris Kolovos escribi]]>Toñi Reina2010-07-11T15:39:49-00:00Re: [Eugenia] Newbie question. Problems in the generated editor with the Folder Item.
https://www.eclipse.org/forums/index.php/mv/msg/171685/546143/#msg_546143
Hi Dimitris,
https://www.eclipse.org/forums/index.php/mv/msg/171685/590630/#msg_590630
Many thanks for confirming that the new version works for you! Regarding
the error label, this is not something controlled by EuGENia. I've also
come across this but never had the motivation to look into it in detail.
Please consider reporting on the solution (when you've found one) here
for the benefit of other users who may come across the same issue in the
future.
Dimitris
> Hi Dimitris,
>> Hi Toni,
>>> You're wellcome.
>>> things.
>>> report?
>> Yes please.
>>> Regards,
>>> Toñi
>> Cheers,
>> Dimitris
>>>> Hi Toni,
>>>> Cheers,
>>>> Dimitris
>>>>> Hi Toni,
>>>>> Cheers,
>>>>> Dimitris
>>>>>> Hi all,
>>>>>> how
>>>>>> properties,
>>>>>> written in
>>>>>> @gmf(foo="bar"),
>>>>>> and I
>>>>>> can
>>>>>> Thanks and regards,
>>>>>> Toñi
>]]>Dimitrios Kolovos2010-07-11T22:53:27-00:00Re: [Eugenia] Newbie question. Problems in the generated editor with the Folder Item.
https://www.eclipse.org/forums/index.php/mv/msg/171685/546168/#msg_546168
future.
Dimitris
> Hi Dimitris,
>> Hi Toni,
>>> You're wellcome.
>>> things.
>>> report?
>> Yes please.
>>> Regards,
>>> Toñi
>> Cheers,
>> Dimitris
>>>> Hi Toni,
>>>> Cheers,
>>>> Dimitris
>>>>> Hi Toni,
>>>>> Cheers,
>>>>> Dimitris
>>>>>> Hi all,
>>>>>> how
>>>>>> properties,
>>>>>> written in
>>>>>> @gmf(foo="bar"),
>>>>>> and I
>>>>>> can
>>>>>> Thanks and regards,
>>>>>> Toñi
