Eclipse Community Forumsjruby, gems and java autocompletes
https://www.eclipse.org/forums/index.php/mv/msg/169093/536791/#msg_536791
I'm looking at enhancing Ruby support in DLTK and realized that there
does not seem to be support for adding/managing gems on the load path of
projects. Did I miss something obvious or is this missing ?
Also support for autocompleting Java is missing. If the project is both
a java project and a (j)ruby project, DLTK should allow autocompletes
from the java namespace in the ruby editor. Is this in the plan ahead ?
If the DLTK team is willing to help, I'm happy to implement this support :)
-- Ketan http://ketan.padegaonkar.name | http://eclipse.org/swtbot]]>Ketan Padegaonkar2010-05-31T01:21:58-00:00Re: jruby, gems and java autocompletes
https://www.eclipse.org/forums/index.php/mv/msg/169093/539809/#msg_539809
There is a plan to provide support for java-based languages in DLTK, so it should help with java completion in jruby.
Definitely, it would be great to have gem dependencies in DLTK, but it depends on time. You can help with it.
