Eclipse Community Forumsflickering virtual table rows
https://www.eclipse.org/forums/index.php/mv/msg/167996/532911/#msg_532911
I've got an application loading data in a virtual table, however some data is not shown in each row. I mean, the row is there, if I select the row the data appears, while if I don't select the row it appears as empty. As far as I can see there is not a pattern, I can have n rows displayed correctly, one "empty", and other m displayed correctly. Even scrolling the table does not produce the row to appear, it seems a display problem.
I've noted the same behaviour on Linux/GTK and Windows Vista/XP.
I'm currently using the SWT jar 3.5.1.v3555a.
Any suggestion?]]>Luca Ferrari2010-05-11T14:32:51-00:00Re: flickering virtual table rows
https://www.eclipse.org/forums/index.php/mv/msg/167996/533334/#msg_533334
snippet151, snippet192) on your machine and notice the difference in the
way virtual tables are handled between your application and the
snippets. May be, that would be a kick-off starting point for you to
differentiate and determine the behavior.
Otherwise, please post a simple SWT snippet that showcase your problem,
so that we should be able to analyze the problem.]]>Praveen 2010-05-13T12:38:49-00:00Re: flickering virtual table rows
https://www.eclipse.org/forums/index.php/mv/msg/167996/543124/#msg_543124
It was my fault, since I was returning a null row (null object) once every few rows, this was causing the label providers to display nothing in the table for such row. When I click such row, the right object was reloaded from the database and displayed well.
It was quite hard to discover.]]>Luca Ferrari2010-06-28T13:27:29-00:00
