Eclipse Community ForumsIs there a tool or plugin for RAP to trace memory use
https://www.eclipse.org/forums/index.php/mv/msg/166457/527664/#msg_527664
I am working on a project with many UI elements. When I run the program, memory usage is pretty high. I want to know if there is a tool or plugin for tracing JAVA memory usage in RAP env?]]>wayne 2010-04-16T02:49:37-00:00Re: Is there a tool or plugin for RAP to trace memory use
https://www.eclipse.org/forums/index.php/mv/msg/166457/527684/#msg_527684
the Memory Analyzer (MAT) is the tool to go for: http://www.eclipse.org/mat/
I think there've been a tutorial how to use it with RAP. But i could not find
it. The tutorial on the projekt homepage should be sufficient.
Pretty cool tool, i already used it for my projects.
Greetings,
-ben
Am 16.04.2010 04:49, schrieb wayne:
> Hi Guys,
> for tracing JAVA memory usage in RAP env?]]>Benjamin Wolff2010-04-16T06:44:19-00:00Re: Is there a tool or plugin for RAP to trace memory use
https://www.eclipse.org/forums/index.php/mv/msg/166457/527975/#msg_527975
Originally posted by: karsten_voigt.gmx.de
just to mention another one :-) I use the visualvm direct from java
(https://visualvm.dev.java.net/). Within that tool you can download some
more plugins that will make life much easier...
wayne schrieb:
> Hi Guys,
> for tracing JAVA memory usage in RAP env?]]>2010-04-17T17:42:32-00:00
