Eclipse Community ForumsDSL Toolkit Build Problems
https://www.eclipse.org/forums/index.php/mv/msg/165763/525212/#msg_525212
the galileo DSL Toolkit (1.0.0M8)for 32-bit windows along with Java 6,
update 16.
Building the project results in 203 build errors and 29 warnings. The
majority of these errros are in 5 Xpand files in the dnc project. There
are also some problems in mindmap2xhtml.qvto.
Should the 1.0.0M8 DSL Toolkit build cleanly?
If so, any suggestions you may have to correct these issues are
appreciated.]]>Rod Hughes2009-09-16T11:29:42-00:00Re: DSL Toolkit Build Problems
https://www.eclipse.org/forums/index.php/mv/msg/165763/584028/#msg_584028
It's probably better to ask on the mailing list of the project from
which that source code comes.
Rod Hughes wrote:
> I am working throug the eclipse Modeling Project book and have
> installed the galileo DSL Toolkit (1.0.0M8)for 32-bit windows along
> with Java 6, update 16.
> There are also some problems in mindmap2xhtml.qvto.
> appreciated.
>]]>Ed Merks2009-09-17T16:29:38-00:00Re: DSL Toolkit Build Problems
https://www.eclipse.org/forums/index.php/mv/msg/165763/525215/#msg_525215
> appreciated.
https://www.eclipse.org/forums/index.php/mv/msg/165763/525223/#msg_525223
version of the DSL Toolkit. There were changes to QVTO since then that
require some changes to the transformation definition.
Best,
Rich]]>Richard Gronback2009-10-21T10:53:28-00:00Re: DSL Toolkit Build Problems
https://www.eclipse.org/forums/index.php/mv/msg/165763/587183/#msg_587183
