Eclipse Community ForumsCode Coverage within a method
https://www.eclipse.org/forums/index.php/mv/msg/16375/52385/#msg_52385
possible to get coverage info for each line of code? So far, I have not
seen an option for this, but being new to the TPTP, I could easily have
overlooked an option.
Michael Giroux]]>Michael Giroux2006-02-01T15:01:48-00:00Re: Code Coverage within a method
https://www.eclipse.org/forums/index.php/mv/msg/16375/52509/#msg_52509
Currently, TPTP's code coverage is at the method level. However, we do
have a feature open for more granular code coverage:
Please feel free to comment on requirements/contribute design/code with
regards to this feature.
Paul
"Michael Giroux" <michael.giroux@bull.com> wrote in message
news:drqigr$677$2@utils.eclipse.org...
> I have seen code coverage down to a method level, hit or missed. Is it
> Thanks
> Michael Giroux]]>Paul Slauenwhite2006-02-02T02:40:00-00:00Re: Code Coverage within a method
https://www.eclipse.org/forums/index.php/mv/msg/16375/53008/#msg_53008
Originally posted by: jkp1974a.cox.net
Paul Slauenwhite wrote:
> Hi Michael,
> Paul
>> Thanks
>> Michael Giroux
Hello.
I'm confused by this comment. (Note that I'm a newbie as well). I was
looking to use TPTP to look at code coverage within a method as well.
Is this the wrong thing? If this doesn't work, are there any
recommendations for code coverage within a method? (I was hoping eclipse
tptp would have this feature...but, it looks like I'm going to have change
gears (this and with the "unknown" status of 1.5/5.0)....
Thanks in advance.
Ken]]>2006-02-06T20:16:48-00:00Re: Code Coverage within a method
https://www.eclipse.org/forums/index.php/mv/msg/16375/53291/#msg_53291
I can see how this may be a little confusing. The Event Specification
for the Java Profiler
( http://www.eclipse.org/tptp/platform/documents/resources/pro filingspec/XML4
Profiling.htm) is for the events that our Java Profiler emits. That said,
our Java Profiler is built on the JVMPI specification that does not support
line level events as opposed to the line number attribute per event that it
does support. The line element can be used by agents that emit Java
Profiler events if they have access to this type of granular information.
Paul
"Ken Po" <jkp1974a@cox.net> wrote in message
news:b43dda9e3e9cbe3883fc4316e869ab7a$1@www.eclipse.org...
> > Hi Michael,
do
> > https://bugs.eclipse.org/bugs/show_bug.cgi?id=122315
with
> > Paul
not
> >> Thanks
> >> Michael Giroux
> Hello.
> I was looking at the event specification for the java profiler and I see
> that line elements are produced.
> http://www.eclipse.org/tptp/platform/documents/resources/pro filingspec/XML4Profiling.htm
> Thanks in advance.
> Ken
>]]>Paul Slauenwhite2006-02-08T18:12:38-00:00Re: Code Coverage within a method
https://www.eclipse.org/forums/index.php/mv/msg/16375/53505/#msg_53505
Originally posted by: adammyatt.hotmail.com
If you're looking for an excellent code coverage tool : http://cobertura.sourceforge.net/]]>2006-02-10T16:31:18-00:00Re: Code Coverage within a method
https://www.eclipse.org/forums/index.php/mv/msg/16375/54423/#msg_54423
Michael Giroux2006-02-22T18:05:09-00:00
