Eclipse Community ForumsMixing planner and slicer for target platforms?
https://www.eclipse.org/forums/index.php/mv/msg/163584/517745/#msg_517745
when configuring provisioned target platforms, I stumbled upon the restriction that you
cannot mix the slicer -> include all environments and planner -> include required software
options. Is this intentional? Couldn't the planner also include all environments? Couldn't
there be at least some sites being sliced and some sites planned in the same target
(currently you can only use slicer XOR planner in the same target platform)? Problem with
the current situation is, if you want to setup a cross-platform-target platform you end up
with listing every dependent bundle/IU yourself - a little bit of help from the planner
would be helpful here :)
