* Drag and Drop example snippet: define a default operation (in this example, Copy)
* For a list of all SWT example snippets see
* http://dev.eclipse.org/viewcvs/index.cgi/%7Echeckout%7E/platform-swt-home/dev.html#snippets
import org.eclipse.swt.SWT;
import org.eclipse.swt.dnd.DND;
import org.eclipse.swt.dnd.DragSource;
import org.eclipse.swt.dnd.DragSourceAdapter;
import org.eclipse.swt.dnd.DragSourceEvent;
import org.eclipse.swt.dnd.DropTarget;
import org.eclipse.swt.dnd.DropTargetAdapter;
import org.eclipse.swt.dnd.DropTargetEvent;
import org.eclipse.swt.dnd.TextTransfer;
import org.eclipse.swt.dnd.Transfer;
import org.eclipse.swt.events.MouseEvent;
import org.eclipse.swt.events.MouseMoveListener;
import org.eclipse.swt.layout.GridLayout;
import org.eclipse.swt.widgets.Label;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.swt.widgets.Text;
public class Snippet84
public static void main(String[] args)
Display display = new Display();
Shell shell = new Shell(display);
shell.setLayout(new GridLayout(2, false));
final Label label = new Label(shell, SWT.BORDER);
label.setText("Drag Source");
DragSource source = new DragSource(label, DND.DROP_COPY | DND.DROP_MOVE | DND.DROP_LINK);
source.setTransfer(new Transfer[] { TextTransfer.getInstance() });
source.addDragListener(new DragSourceAdapter()
public void dragSetData(DragSourceEvent event)
event.data = "Text Transferred";
public void dragFinished(DragSourceEvent event)
if (event.doit)
String operation = null;
switch (event.detail)
case DND.DROP_MOVE:
operation = "moved";
break;
case DND.DROP_COPY:
operation = "copied";
break;
case DND.DROP_LINK:
operation = "linked";
break;
case DND.DROP_NONE:
operation = "disallowed";
break;
default:
operation = "unknown";
break;
label.setText("Drag Source (data " + operation + ")");
else
label.setText("Drag Source (drag cancelled)");
final Text text = new Text(shell, SWT.BORDER | SWT.MULTI);
text.setText("Drop Target");
DropTarget target = new DropTarget(text, DND.DROP_DEFAULT | DND.DROP_COPY | DND.DROP_MOVE
| DND.DROP_LINK);
target.setTransfer(new Transfer[] { TextTransfer.getInstance() });
target.addDropListener(new DropTargetAdapter()
public void dragEnter(DropTargetEvent event)
if (event.detail == DND.DROP_DEFAULT) event.detail = DND.DROP_COPY;
public void dragOperationChanged(DropTargetEvent event)
public void drop(DropTargetEvent event)
case DND.DROP_MOVE:
break;
case DND.DROP_COPY:
break;
case DND.DROP_LINK:
break;
case DND.DROP_NONE:
break;
default:
break;
text.append("\n" + operation + (String) event.data);
shell.setSize(400, 400);
final Label label1 = new Label(shell, SWT.BORDER);
label1.setText("TEST");
shell.addMouseMoveListener(new MouseMoveListener()
public void mouseMove(MouseEvent e)
label1.setText(e.x + " " + e.y);
System.out.println(e.x + " " + e.y);
shell.open();
while (!shell.isDisposed())
if (!display.readAndDispatch()) display.sleep();
display.dispose();
