Eclipse Community Forumscustom touchpoint action troubles
https://www.eclipse.org/forums/index.php/mv/msg/161605/510747/#msg_510747
does custom touchpoint action work for anybody?
I had a project which was used to use installHandler to create batch file in system directory with content based on some application logic.
In Galileo the installHandlers are not supported no more. Well, I have to rewrite it to be suitable for equnox p2.
Now I have lets say example project with one plugin and one feature containing this plugin. In plugin I have MyProvisioningAction extending ProvisioningAction (it does new File() and write something into this) and it is registered in plugin.xml as follows:
In state above this install/update process is finished without error even in error log view but no new File is created as expected from myProvisioningAction.
I had also attempt where install and update were stated in p2.inf of plugin but it results in error while creating action with id: myAction().
Does anybody passed through it and have custom action working?
