Eclipse Community Forumsgenerate plugin
https://www.eclipse.org/forums/index.php/mv/msg/159957/505320/#msg_505320
having worked with XText for the last week, I now want to generate one or more eclipse plugin containing the editor for my language.
How do I do that ? I can find no informations in user guide.
Thanks for this wonderful plugin, that make impossible possible.]]>Nicolas Delsaux2009-12-29T10:07:23-00:00Re: generate plugin
https://www.eclipse.org/forums/index.php/mv/msg/159957/505339/#msg_505339
don't know if i understand you problem. But if you want to install the editor-plugins to another eclipse just export the plugin-projects you created with the xtext wizard using the std eclipse plugin export mechanism (mark projects -> right click -> Export -> Plug-In Development -> Deployable plugins and fragments)]]>Christian Dietrich2009-12-29T17:15:04-00:00Re: generate plugin
https://www.eclipse.org/forums/index.php/mv/msg/159957/505423/#msg_505423
Anoway, now i've exported my code as plugin, I try to put it in an already existing Eclipse installation.
But nothing happens : my plugins are not visible in the help dialog, their preferences panel is neither visible, and there is no log in the console.
is there any kind of issue related to the lack of jar signing ? (I didn't wanted to sign my plugins, since they are only development versions but, if required, i can do it).]]>Nicolas Delsaux2009-12-30T08:50:04-00:00Re: generate plugin
https://www.eclipse.org/forums/index.php/mv/msg/159957/505693/#msg_505693
The solution for me, was to install Xtext, Xpand and MWE from http://download.eclipse.org/releases/galileo using the eclipse update manager.
My plugins work fine now. But I can't generate any code, because trying to execute an MWE workflow results in an error message ("Could not execute workflow: org.eclipse.emf.mwe.core.WorkflowRunner needs to be on the class path.")
]]>Johannes Degler2010-01-04T09:29:25-00:00Re: generate plugin
https://www.eclipse.org/forums/index.php/mv/msg/159957/505704/#msg_505704
]]>Johannes Degler2010-01-04T10:16:21-00:00Re: generate plugin
https://www.eclipse.org/forums/index.php/mv/msg/159957/505700/#msg_505700
> the class path.")
The message indicates that the org.eclipse.emf.mwe.core bundle (read
jar) is not on the classpath of the project (containing the MWE file).
Sven
Need professional support for Xtext and EMF?
Go to: http://xtext.itemis.com
Twitter : @svenefftinge
Blog : blog.efftinge.de]]>Sven Efftinge2010-01-04T15:05:54-00:00Re: generate plugin
https://www.eclipse.org/forums/index.php/mv/msg/159957/505712/#msg_505712
Your solution also worked for me.
Notice that, for full use, no editor must be open for a file of this type before all the plugins are installed.]]>Nicolas Delsaux2010-01-04T16:08:06-00:00Re: generate plugin
https://www.eclipse.org/forums/index.php/mv/msg/159957/505801/#msg_505801
Federico Tomassetti2010-01-05T07:03:42-00:00Re: generate plugin
https://www.eclipse.org/forums/index.php/mv/msg/159957/665111/#msg_665111
I'm working with Xtext and I have kind of a similar problem.
I did generate the plugin exporting it through Eclipse but when I'm editing my file no code completion is shown, even though it works fine when I run the project as an Eclipse Application.
Am I missing some details in configuration so I can keep enjoying all the facilities that Xtext editor offers me?
Thanks,]]>betty jhonson2011-04-13T10:23:00-00:00Re: generate plugin
https://www.eclipse.org/forums/index.php/mv/msg/159957/665126/#msg_665126
show some error/warning?
Am 13.04.11 12:23, schrieb Betania:
> Hi all,
> I'm working with Xtext and I have kind of a similar problem. I did
Go visit: http://xtext.itemis.com]]>Jan Koehnlein2011-04-13T11:37:14-00:00Re: generate plugin
https://www.eclipse.org/forums/index.php/mv/msg/159957/665132/#msg_665132
There's no error shown in the console or .log file in .metadata folder in my workspace.
Is there anywhere else where I can find log?
Any ideas? Thanks,]]>betty jhonson2011-04-13T12:12:51-00:00Re: generate plugin
https://www.eclipse.org/forums/index.php/mv/msg/159957/1656834/#msg_1656834
Thanks in advance!
BR,
Mike]]>Michael Ngangom2015-03-07T18:05:51-00:00Re: generate plugin
https://www.eclipse.org/forums/index.php/mv/msg/159957/1661158/#msg_1661158
can you be a bit more specific what you mean by
- embed the functionality in the editor
- make this as a plug in application
]]>Christian Dietrich2015-03-09T14:01:52-00:00Re: generate plugin
https://www.eclipse.org/forums/index.php/mv/msg/159957/1661178/#msg_1661178
Thanks a lot for the reply. I will try to elaborate what I am trying to do:
I am trying to create an fully fledged editor and I was able to define the grammar which will basically highlight the keywords and has the auto complete features. However, I am trying to make the code executable -like able to give functionality to the editor. eg: I have the below query written
Select <field> from <table>;
and I want to execute the query above using the the newly developed editor. I will be using some APIs to run the query, I just want to know how can I embed these APIs functionality to the editor and make the whole editor as an eclipse plugin.
Michael]]>Michael Ngangom2015-03-09T14:11:06-00:00Re: generate plugin
https://www.eclipse.org/forums/index.php/mv/msg/159957/1661207/#msg_1661207
have a look at YourDslGenerator and or use https://christiandietrich.wordpress.com/2011/10/15/xtext-calling-the-generator-from-a-context-menu/ as starting point]]>Christian Dietrich2015-03-09T14:26:28-00:00Re: generate plugin
https://www.eclipse.org/forums/index.php/mv/msg/159957/1661255/#msg_1661255
]]>Michael Ngangom2015-03-09T14:53:52-00:00
