Eclipse Community ForumsSeparate Workspace files from project completely?
https://www.eclipse.org/forums/index.php/mv/msg/159035/502278/#msg_502278
I want those to be generated in the workspace instead, not in the project dir. Any idea how to do that?
Thanks]]>James Carr2009-12-07T15:11:33-00:00Re: Separate Workspace files from project completely?
https://www.eclipse.org/forums/index.php/mv/msg/159035/502280/#msg_502280
The only way to do what you want would be to create a project in the workspace, and then start adding linked folders and linked source folders to your "real" project in some other location on the file system.
That way the top level of the <project> is pointing to a directory in the workspace and won't effect your external directory tree.
PW
]]>Paul Webster2009-12-07T15:19:00-00:00Re: Separate Workspace files from project completely?
https://www.eclipse.org/forums/index.php/mv/msg/159035/502284/#msg_502284
]]>James Carr2009-12-07T15:30:35-00:00
