Eclipse Community ForumsLoad a XMI file with xmlns:uml tag < 3.0.0
https://www.eclipse.org/forums/index.php/mv/msg/157131/495436/#msg_495436
can somebody explain how we can load a XMI file with an old xmlns:uml Tag (for example: xmlns:uml="http://www.eclipse.org/uml2/2.2.0/UML) without the gui in an own java application?
Thanks]]>HTWTeam 2009-11-04T20:50:02-00:00Re: Load a XMI file with xmlns:uml tag < 3.0.0
https://www.eclipse.org/forums/index.php/mv/msg/157131/495528/#msg_495528
Do you mean that you have a xml coming from an UML model and you would like to create java code or would you like to create graphical views ?
]]>Vlad Varnica2009-11-05T09:23:33-00:00Re: Load a XMI file with xmlns:uml tag < 3.0.0
https://www.eclipse.org/forums/index.php/mv/msg/157131/495575/#msg_495575
--------------090801040907010208040102
Maybe the details for "Programmatic Migration" here are similar:
HTWTeam wrote:
> Hello,
> Thanks
--------------090801040907010208040102--]]>Ed Merks2009-11-05T11:39:55-00:00Re: Load a XMI file with xmlns:uml tag < 3.0.0
https://www.eclipse.org/forums/index.php/mv/msg/157131/495824/#msg_495824
Vlad Varnica wrote on Thu, 05 November 2009 04:23
I don't understand the question
Yes, I have a XMI that coming from an UML model. But I don't want to create java code or graphical views rather simple load the XMI model for count all classes in it.
With an new xmi file (3.0.1 uml Tag) it works but older models could not be load.
Ed Merks wrote on Thu, 05 November 2009 06:39
I have read it but don't find the methods for programmatic migration.]]>HTWTeam 2009-11-06T10:06:22-00:00Re: Load a XMI file with xmlns:uml tag < 3.0.0
https://www.eclipse.org/forums/index.php/mv/msg/157131/495881/#msg_495881
--------------060002060803030107000608
When you say you don't find it, are you saying you didn't find the
section like this or it didn't work?
In order to migrate models programmatically, some setup is required
in order to register mappings (already defined by UML). These
mappings will be used by the resource set during the loading stage
and will perform the necessary in-memory migration.
The example below demonstrates how one can migrate models with a
stand-alone application.
>> I don't understand the question :blush: Do you mean that you have a
> not be load.
>> http://www.eclipse.org/modeling/mdt/uml2/docs/guides/UML2_2.
>> 0_Migration_Guide/guide.html
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
section like this or it didn't work?<o:p> </o:p>
<blockquote>
<h2><!--[if gte vml 1]><v:shape id="_x0000_i1045" type="#_x0000_t75" alt=""
style='width:9.75pt;height:9.75pt'>
<v:imagedata src="" o:href="http://www.eclipse.org/modeling/mdt/images/new.gif"/>
</v:shape><![endif]--><span
style=""> </span>Programmatic
Migration</h2>
<p class="MsoNormal"><o:p> </o:p><br>
required in order to register mappings (already defined by UML).<span
style=""> </span>These mappings will be used by the resource
set during the loading stage and will perform the necessary in-memory
migration.</p>
<p class="MsoNormal"><o:p> </o:p>The example below demonstrates how
one can <span class="GramE">migrate</span> models with a stand-alone
application.<br>
</p>
</blockquote>
<p class="MsoNormal"><br>
</p>
<br>
<br>
HTWTeam wrote:
<blockquote cite="mid:hd0sf0$tac$1@build.eclipse.org" type="cite">Vlad
<br>
<blockquote type="cite">I don't understand the question :blush: Do
<br>
</blockquote>
<br>
<br>
<br>
<br>
not be load.
<br>
<br>
<br>
<blockquote type="cite">Maybe the details for "Programmatic
Migration" here are similar: <br>
<a class="moz-txt-link-freetext" href="http://www.eclipse.org/modeling/mdt/uml2/docs/guides/UML2_2">http://www.eclipse.org/modeling/mdt/uml2/docs/guides/UML2_2</a>.
<br>
</blockquote>
<br>
<br>
</blockquote>
</body>
</html>
