Eclipse Community ForumsPossible to use the JWT editor but for a different model?
https://www.eclipse.org/forums/index.php/mv/msg/156958/494812/#msg_494812
For example, the activity component is analogous to our "Flow" component, but we also have many more "Action" types that would need to be part of the flow. Perhaps I could get away with renaming Activity to our Flow component name, but then I also need to modify the model to incorporate the additional Action types, eventually removing the generic Action altogether.
Any ideas on the best way to achieve this?]]>Sed Mising name2009-11-02T17:55:37-00:00Re: Possible to use the JWT editor but for a different model?
https://www.eclipse.org/forums/index.php/mv/msg/156958/494988/#msg_494988
Have a look at the EPC plugin (by the University of Augsburg) :
in the CVS, at org.eclipse.jwt/we/jwt-we-plugins/jwt-we-view-epc
In addition to providing a customized view with custom figures and icons
that have a completely different outlook from the default one, it
provides an additional "EPCEvent" workflow model element that should
show you how to add your own.
I wouldn't advise you to change the existing model for fear of breaking
things, but you can change the text that is displayed for a given model
element in the plugin.properties (ex. Action -> Flow). As shown in the
EPC View sample, you can also change and extend a lot of other things
(1), including adding new model elements by subclassing or using EMF
Aspect-like extensions that we provide :
Josh a écrit :
> I am currently developing a custom workflow and that effort has led me
> to discover this project. All the functionality that the JWT editor has
> seems to be exactly what I would like to use for my development efforts,
> except that I need to back it with a custom model, essentially replacing
> most to the model components with ones specific to our needs.
> Action altogether.
> Any ideas on the best way to achieve this?]]>Marc Dutoo2009-11-03T13:32:16-00:00Re: Possible to use the JWT editor but for a different model?
https://www.eclipse.org/forums/index.php/mv/msg/156958/495150/#msg_495150
Sed Mising name2009-11-03T22:25:59-00:00Re: Possible to use the JWT editor but for a different model?
https://www.eclipse.org/forums/index.php/mv/msg/156958/495277/#msg_495277
that core developers are more likely to monitor and be ready to answer
questions on : jwt-dev@eclipse.org
Marc
Josh a écrit :
> Thanks for the reply! I will take a look!]]>Marc Dutoo2009-11-04T13:22:45-00:00
