Eclipse Community ForumsHow to add problem entries to the problem view?
https://www.eclipse.org/forums/index.php/mv/msg/152807/481197/#msg_481197
In our rcp, before sending a model to the our own analyse engine, we need
to check if the model is valid. And if we find there are some problems or
errors defined by us, I want to display them in the problem view.
Does problem view support this? How to realize it?
Any comments are welcome. Thanks!!
Li]]>Li Junhong2009-08-20T06:39:49-00:00Re: How to add problem entries to the problem view?
https://www.eclipse.org/forums/index.php/mv/msg/152807/481355/#msg_481355
think is the most appropriate group and if there is a better place then
someone will guide you to it.
Li Junhong wrote:
> Hi All,
> need to check if the model is valid. And if we find there are some
> problems or errors defined by us, I want to display them in the problem
> view.
> Li
>]]>Eric Rizzo2009-08-20T15:04:15-00:00
