Eclipse Community ForumsReplacing UML2::NamedElement::isDistinguishableFrom with new operation i a profile?
https://www.eclipse.org/forums/index.php/mv/msg/149570/470224/#msg_470224
I got a use case where I need to replace the built in
NamedElement::isDistinguishableFrom query with another customized query
that also considers the NamedElement::type in the comparison.
Is this possible to do with current UML2 implementation using a new
profile where I define a new overriden/redefined operation
isDistinguishableFrom() for a stereotype <<MyClass>> ?
NamedElement::isDistinguishableFrom(n:NamedElement, ns: Namespace): Boolean;
isDistinguishable =
if self.oclIsKindOf(n.oclType) or n.oclIsKindOf(self.oclType)
then
ns.getNamesOfMember(self)->intersection(ns.getNamesOfMember(n))- >isEmpty()
else true
thanks
/anders]]>user2007-02-08T22:54:11-00:00Re: Replacing UML2::NamedElement::isDistinguishableFrom with new operation i a profile?
https://www.eclipse.org/forums/index.php/mv/msg/149570/470226/#msg_470226
Unfortunately you cannot override such behavior in a profile. You might
want to consider some form of UML extension to accomplish this.
Have a look at the draft form of the "Extending UML" articles here https://bugs.eclipse.org/bugs/show_bug.cgi?id=77413 .... They explain the
pros and cons of extending UML and explore some options you have at your
disposal.
- James.
<user@domain.com> wrote in message news:eqg9mk$321$1@utils.eclipse.org...
> Boolean;
> isDistinguishable =
> then
> else true
> thanks
> /anders
>]]>james bruck2007-02-09T03:33:12-00:00Re: Replacing UML2::NamedElement::isDistinguishableFrom with new operation i a profile?
https://www.eclipse.org/forums/index.php/mv/msg/149570/586721/#msg_586721
disposal.
- James.
> Boolean;
> isDistinguishable =
> then
> else true
> thanks
> /anders
https://www.eclipse.org/forums/index.php/mv/msg/149570/588584/#msg_588584
Sorry to hear this, It would have been super if possible. Ill have alook
at the articles but unfortunately compliance is important in the use case.
By any chance you dont know what, in the UML2 spec, that disallows
compliant appl to redefine such queries in a profile? and where in the
profiles chapter I can find these rules?
thanks
/anders
James Bruck wrote:
> Hi Anders,
> disposal.
> Regards,
> - James.
>> Hi,
>> Boolean;
>> isDistinguishable =
>> then
>> else true
>> thanks
>> /anders
>]]>user2007-02-13T07:41:57-00:00Re: Replacing UML2::NamedElement::isDistinguishableFrom with new operation i a profile?
https://www.eclipse.org/forums/index.php/mv/msg/149570/470383/#msg_470383
thanks
/anders
James Bruck wrote:
> Hi Anders,
> disposal.
> Regards,
> - James.
>> Hi,
>> Boolean;
>> isDistinguishable =
>> then
>> else true
>> thanks
>> /anders
https://www.eclipse.org/forums/index.php/mv/msg/149570/588659/#msg_588659
While the specification doesn't explicitly state that behavior cannot be
overridden by a profile, it does state that the purpose of a profile is to
constrain and/or extend a metamodel. The mechanism for overriding behavior
(and structure) in UML is redefinition, but since redefinition can only be
done in the context of generalization, and stereotypes can only specialize
stereotypes (not metaclasses), profiles effectively cannot be used to
redefine behavior in the metamodel...
Kenn
<user@domain.com> wrote in message news:45D16BC5.7040002@domain.com...
> Hi James,
> thanks
> /anders
> James Bruck wrote:
>> Hi Anders,
>> might want to consider some form of UML extension to accomplish this.
>> the pros and cons of extending UML and explore some options you have at
>> your disposal.
>> Regards,
>> - James.
>>> Hi,
>>> Boolean;
>>> isDistinguishable =
>>> then
>>> else true
>>> thanks
>>> /anders
>>]]>Kenn Hussey2007-02-13T21:00:16-00:00Re: Replacing UML2::NamedElement::isDistinguishableFrom with new operation i a profile?
https://www.eclipse.org/forums/index.php/mv/msg/149570/470402/#msg_470402
Kenn
> Hi James,
> thanks
> /anders
> James Bruck wrote:
>> Hi Anders,
>> your disposal.
>> Regards,
>> - James.
>>> Hi,
>>> Boolean;
>>> isDistinguishable =
>>> then
>>> else true
>>> thanks
>>> /anders
