Eclipse Community ForumsEditor error
https://www.eclipse.org/forums/index.php/mv/msg/149356/469673/#msg_469673
(Ganymede, 3.4). It appears to integrate OK. When I try to edit a new
COBOL program or open an existing COBOL program (from the filesystem), I
get the following error:
Could not open the editor: The editor class could not be instantiated.
This usually indicates a missing no-arg constructor or that the editor's
class name was mistyped in plugin.xml.
When I click on Details>> I get the following:
java.lang.NoClassDefFoundError: org/eclipse/swt/custom/StyledText2
at org.eclipse.cobol.ui.editor.COBOLEditor.<init>(COBOLEditor.java:558)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Nativ e Method)
at
sun.reflect.NativeConstructorAccessorImpl.newInstance(Native ConstructorAccessorImpl.java:57)
at
sun.reflect.DelegatingConstructorAccessorImpl.newInstance(De legatingConstructorAccessorImpl.java:45)
at java.lang.reflect.Constructor.newInstance(Constructor.java:5 32)
at java.lang.Class.newInstance0(Class.java:372)
at java.lang.Class.newInstance(Class.java:325)
at
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:170)
at
org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:867)
at
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
at
org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
at org.eclipse.ui.internal.WorkbenchPlugin$1.run(WorkbenchPlugi n.java:267)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
at
org.eclipse.ui.internal.WorkbenchPlugin.createExtension(Work benchPlugin.java:263)
at
org.eclipse.ui.internal.registry.EditorDescriptor.createEdit or(EditorDescriptor.java:233)
at
org.eclipse.ui.internal.EditorManager.createPart(EditorManag er.java:846)
at
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:606)
at
org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:428)
at
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:594)
at
org.eclipse.ui.internal.EditorAreaHelper.setVisibleEditor(Ed itorAreaHelper.java:263)
at
org.eclipse.ui.internal.EditorManager.setVisibleEditor(Edito rManager.java:1410)
at
org.eclipse.ui.internal.EditorManager$5.runWithException(Edi torManager.java:944)
at
org.eclipse.ui.internal.StartupThreading$StartupRunnable.run (StartupThreading.java:31)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:133)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3378)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3036)
at
org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:803)
at
org.eclipse.ui.internal.Workbench$25.runWithException(Workbe nch.java:1361)
at
at
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2293)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:21 98)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:493)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:488)
at
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:382)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:57)
at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:616)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 549)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
at org.eclipse.equinox.launcher.Main.run(Main.java:1236)
Caused by: java.lang.ClassNotFoundException:
org.eclipse.swt.custom.StyledText2
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:481)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:397)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:385)
at
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:87)
at java.lang.ClassLoader.loadClass(ClassLoader.java:268)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:336 )
... 53 more
I've search many places for an error like this and have yet to find a
solution. Any help would be appreciated. Thanks.
Rich.]]>Rich Smrcina2009-05-12T19:15:56-00:00Re: Editor error
https://www.eclipse.org/forums/index.php/mv/msg/149356/469674/#msg_469674
How abount using Eclipse 3.4.1 instead?]]>Tetsuya Suehisa2009-05-13T07:07:02-00:00Re: Editor error
https://www.eclipse.org/forums/index.php/mv/msg/149356/469675/#msg_469675
Rich]]>Rich Smrcina2009-05-14T01:29:20-00:00Re: Editor error
https://www.eclipse.org/forums/index.php/mv/msg/149356/469676/#msg_469676
An additional problem, now. I'm trying to edit an existing program by
importing it into a project. When I open it in the editor, it appears to
overrun the left margin of the editor by 5 characters. In other words,
the text starts 5 characters to the left of the editing position.
I have the COBOL tab stop set to 8. This file was originally edited with
vi. The lines in the file (at least the first few that I've looked at)
have x'09' as the first character.
I can send a screen shot via email if it's easier to visualize.
Rich.]]>Rich Smrcina2009-05-15T16:36:57-00:00Re: Editor error
https://www.eclipse.org/forums/index.php/mv/msg/149356/469677/#msg_469677
Thank you for reporting. Sorry to trouble you, but would you issue a bug
report with the screenshot by eclipse bugzilla?
Best Regards,
Tetsuya]]>Tetsuya Suehisa2009-05-18T21:22:49-00:00Re: Editor error
https://www.eclipse.org/forums/index.php/mv/msg/149356/469678/#msg_469678
Thanks for your quick support.
