Eclipse Community Forums[ANN] Instantiations WindowBuilder Pro 4.0 released
https://www.eclipse.org/forums/index.php/mv/msg/1481/4129/#msg_4129
Originally posted by: mark5.instantiations.com
Major new release includes support for JGoodes FormLayout support, SWT_AWT
support,
SWT Spinner, Link, TreeColumn, TreeItem & TableItem support, enhanced
keyboard navigation,
custom swing properties & editors, better custom widget support, code
hiding, improved
SWT FormLayout support, Eclipse 3.1 M6 support plus many other new features.
a.. Support for Eclipse 3.1 M6 & Eclipse 3.0.2
b.. Support for the SWT_AWT bridge allowing SWT and Swing to be mixed
a.. New SWT_AWT palette
b.. Embed any Swing widget into an SWT or RCP window
c.. Support for JGoodies FormLayout
a.. Graphically manage columns and rows
b.. Graphically manage cell alignment and column/row spanning
c.. Graphically reorder and resize columns and rows
d.. Automatically handle gap columns and rows
e.. Intelligently convert existing layouts to JGFL
f.. Support for different units like pixels and dialog units
g.. Support for all predefined FormLayout types
h.. Support for grouping and ungrouping columns
i.. Color highlighting for grouped columns and rows
j.. Floating layout assistant for cells, columns and rows
k.. Intelligently merge and split columns and rows
d.. Support for new Eclipse 3.1 SWT elements
a.. Support for the SWT Spinner & Link control
b.. Support for the SWT TreeColumns
c.. Support for virtual tables
e.. Enhanced SWT support
a.. Support for SWT DragSource & DropTarget and custom SWT drag/drop
transfer classes
b.. Support for SWT TableItems & TreeItems
c.. Support for SWT Cursor property
d.. Support for strikeout and underline properties for SWT fonts
(Windows-only)
e.. Support for new 3.0 SWT RowLayout properties
f.. Enhanced SWT FormLayout support
f.. Enhanced JFace support
a.. Support for ApplicationWindow coolbars
b.. Property support for JFace Action styles & accelerators
c.. Icon support for SWT Dialogs, TitleAreaDialogs and
ApplicationWindows
d.. Support for Shell events in ApplicationWindow
g.. Enhanced Swing support
a.. Support for custom Swing properties, editors and customizers
b.. Support for instantiating custom JTable/JTree/JComboBox models
c.. Added support for parsing and editing JTable columns
h.. Enhanced NLS support
a.. Enhanced NLS support to allow selection of any messages class
b.. Added ability to auto-externalize strings for newly added widgets
i.. Editor & Property Pane enhancements
j.. Code Parsing enhancements]]>2005-04-05T22:53:27-00:00[ANN] v4.0 - SWT Designer, Swing Designer & WindowBuilder
https://www.eclipse.org/forums/index.php/mv/msg/1481/4200/#msg_4200
support, SWT Spinner, Link, TreeColumn, TreeItem & TableItem support,
enhanced keyboard navigation, custom swing properties & editors, better
custom widget support, code hiding, improved SWT FormLayout support, Eclipse
o Support for the SWT_AWT bridge allowing SWT and Swing to be mixed
-- New SWT_AWT palette
-- Embed any Swing widget into an SWT or RCP window
o Support for JGoodies FormLayout
-- Graphically manage columns and rows
-- Graphically manage cell alignment and column/row spanning
-- Graphically reorder and resize columns and rows
-- Automatically handle gap columns and rows
-- Intelligently convert existing layouts to JGFL
-- Support for different units like pixels and dialog units
-- Support for all predefined FormLayout types
-- Support for grouping and ungrouping columns
-- Color highlighting for grouped columns and rows
-- Floating layout assistant for cells, columns and rows
-- Intelligently merge and split columns and rows
o Support for new Eclipse 3.1 SWT elements
-- Support for the SWT Spinner & Link control
-- Support for the SWT TreeColumns
-- Support for virtual tables
o Enhanced SWT support
-- Support for SWT DragSource & DropTarget
-- Support for SWT TableItems & TreeItems
-- Support for SWT toggle buttons
-- Support for SWT Cursor property
-- Support for strikeout and underline properties for SWT fonts
(Windows-only)
-- Support for new 3.0 SWT RowLayout properties
-- Enhanced SWT FormLayout support
-- Support for SWT color constants sources
-- Support for custom SWT drag/drop transfer classes
o Enhanced JFace support
-- Support for ApplicationWindow coolbars
-- Style property support for JFace Action
-- Icon support for SWT Dialogs, TitleAreaDialogs and ApplicationWindows
-- Support for Shell events in ApplicationWindow
-- Support for JFace action accelerator property
o Enhanced Swing support
-- Support for custom Swing properties and editors
-- Support for custom Swing widget customizers
-- Support for superclasses in Swing JFrame wizard
-- Keyboard navigation support for all Swing layouts
-- Support for GridBagConstraints subclasses with custom defaults
-- Support for instantiating custom JTable/JTree/JComboBox models
-- Added support for parsing and editing JTable columns
-- Tooltips for GBL selection handles, with option on preference page
-- Support for static method factory for GridBagConstraints
-- Support for custom component icons in tree and palette
o Enhanced NLS support
-- Added flag for copying default values in all locales
-- Enhanced NLS support to allow selection of any messages class
-- Added flag in "New Local" dialog to copy default values to new
properties file
-- Added ability to auto-externalize strings for newly added widgets
o Editor & Property Pane enhancements
-- Use Ctrl key to add custom widgets by name
-- Automatically add to Custom Controls palette via Choose Bean
-- Support for mouse wheel in property table when design canvas is active
-- Support for copy/paste (Ctrl+C/X/V) in text property editors
-- Added tooltips for most component properties
o Code Parsing enhancements
-- Support for code hiding
-- Support for default string property value when expression can not be
converted
All three products are available immediately for Eclipse 2.1, 3.0, 3.1 M6,
IBM WebSphere Studio 5.1.2 and Rational Application Developer 6.0 running on
Windows 2000/XP or Linux/GTK2. The price per developer for WindowBuilder Pro
is $299, SWT Designer is $199 and Swing Designer is $199.]]>Eric Clayberg2005-04-06T05:09:54-00:00[ANN] v4.0 - SWT Designer, Swing Designer & WindowBuilder
https://www.eclipse.org/forums/index.php/mv/msg/1481/560619/#msg_560619
(Windows-only)
properties file
converted
