Eclipse Community Forumsheadless build - avoid jaring of a plugin being available as directory
https://www.eclipse.org/forums/index.php/mv/msg/14551/46285/#msg_46285
currently i am trying build a product using pde-headless build which
should contain plugins which should NOT be jared by the headless build ...
with no success (The plugin in question contains an embedded jetty+h2
database).
I defined my product using a *.product file which works fine already. But
i cannot manage to avoid jaring the plugin containing the embedded jetty.
Could anybody give me a hint where to set the correct switch :-) ?
Any help is appreciated,
Thomas E.-E.]]>Thomas ichstädt-Engelen2009-02-10T15:49:52-00:00Re: headless build - avoid jaring of a plugin being available as directory
https://www.eclipse.org/forums/index.php/mv/msg/14551/591769/#msg_591769
> ... with no success (The plugin in question contains an embedded
> jetty+h2 database).
> But i cannot manage to avoid jaring the plugin containing the embedded
> jetty.
> Thomas E.-E.
Chris Aniszczyk | EclipseSource Austin | +1 860 839 2465 http://twitter.com/caniszczyk | http://twitter.com/eclipsesource]]>Chris Aniszczyk2009-02-10T16:23:58-00:00Re: headless build - avoid jaring of a plugin being available as directory
https://www.eclipse.org/forums/index.php/mv/msg/14551/46317/#msg_46317
> jetty+h2 database).
> jetty.
> Thomas E.-E.
Yes: this blog provides the "recognition algorythm" but
No: I do use Ganymede (unfortunately)
But anyhow, many thanks for this link,
Thomas E.-E.]]>Thomas ichstädt-Engelen2009-02-11T07:24:29-00:00Re: headless build - avoid jaring of a plugin being available as directory
https://www.eclipse.org/forums/index.php/mv/msg/14551/591814/#msg_591814
> http://eclipsesource.com/blogs/2009/01/20/tip-eclipse-bundle shape/
> Does this help?
yes and no ;-)
