Eclipse Community ForumsHow to set the minimum size to a scrolled composite??
https://www.eclipse.org/forums/index.php/mv/msg/141003/444491/#msg_444491
IŽve developed a scrolled composite but IŽd like to set the minimun
size (width). How can I do this? This behaviour is seen inside from
Eclipse when we increased the Package Explorer. I need to implement this
same behaviour in my plugin...
Andréa]]>andrea2004-10-13T19:40:43-00:00Re: How to set the minimum size to a scrolled composite??
https://www.eclipse.org/forums/index.php/mv/msg/141003/444501/#msg_444501
ScrolledComposite. If you are using a Sash (the way PackageExplorer is
resized inside Eclipse), have a look at the following example:
