Eclipse Community ForumsTeneo Ant problem
https://www.eclipse.org/forums/index.php/mv/msg/135634/426313/#msg_426313
exporting my plugin projects, and I cannot set my Ant preferences.
See bug 254899.
Is there any work around?]]>J F2008-12-23T10:47:27-00:00Re: Teneo Ant problem
https://www.eclipse.org/forums/index.php/mv/msg/135634/426314/#msg_426314
The bugzilla mentions the plugin
org.eclipse.emf.teneo.hibernate.libraries
which is not part of the sdk or runtime (which is correct). How did you install this plugin?
gr. Martin
JF wrote:
> When I Install Teneo on a vanilla Eclipse 3.4.1 it seems to stop me from
> exporting my plugin projects, and I cannot set my Ant preferences. See
> bug 254899. Is there any work around?
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Web: www.springsite.com - www.elver.org]]>Martin Taal2008-12-23T12:03:14-00:00Re: Teneo Ant problem
https://www.eclipse.org/forums/index.php/mv/msg/135634/426315/#msg_426315
When I replicated it on my clean install I used the update site http://download.eclipse.org/modeling/emf/updates/interim/ to install it,
using p2. I selected the M200812170122 of Teneo from what p2 showed me and
let it work out the rest. HOWEVER, I have been looking at it in my normal
eclipse config and workspace in order to track down what is happening. So
I'll redo the vanilla install and check that the same problem is causing
the error.
Back soon]]>J F2008-12-23T12:31:47-00:00Re: Teneo Ant problem
https://www.eclipse.org/forums/index.php/mv/msg/135634/426316/#msg_426316
is downloaded when you download the Teneo examples. This happens with P2
if you select the top level check box for the Teneo download.
I suppose the workaround is to uninstall/not install the Teneo examples
for now, do a hand install of the examples as necessary with a modified
hibernate libraries...]]>J F2008-12-23T12:48:05-00:00Re: Teneo Ant problem
https://www.eclipse.org/forums/index.php/mv/msg/135634/426317/#msg_426317
Hmm, yes it is present in both examples and test. Can you let me know if the uninstall of the
samples/tests indeed solves the issue?
If so it would be great if you can enter a bugzilla for this for Teneo so I can either remove this
plugin from the examples/tests or make the export packages more precise in hibernate.libraries.
gr. Martin
JF wrote:
> Downloading this now, but it would seem that the hibernate libraries
> part is downloaded when you download the Teneo examples. This happens
> with P2 if you select the top level check box for the Teneo download. I
The Netherlands
Web: www.springsite.com - www.elver.org]]>Martin Taal2008-12-23T13:00:42-00:00Re: Teneo Ant problem
https://www.eclipse.org/forums/index.php/mv/msg/135634/426321/#msg_426321
Another partial fix is creating a org.eclipse.ant.core.prefs in
Workspace\.metadata\.plugins\org.eclipse.core.runtime\.setti ngs with
content along the following lines (I still get probelms with the ant
preferences dialog but the setting still seem to be there);
