Eclipse Community Forumsexternal compare editor failed
https://www.eclipse.org/forums/index.php/mv/msg/13346/42032/#msg_42032
not actually trying to use an external editor. I was assuming it would use
the internal one.
"External compare was failed.
Cannot run program "C:/Program": CreateProcess error=2, The system cannot
find the file specified"
I guess it can't find the executable compare editor. Can it be set to use
the default eclipse compare editor?
more info
Just as test, if I install tortoiseSVN it finds the tortoise compare
editor.
Caused by: java.io.IOException: CreateProcess error=2, The system cannot
find the file specified]]>stuart mellanby2009-02-22T11:24:37-00:00Re: external compare editor failed
https://www.eclipse.org/forums/index.php/mv/msg/13346/42065/#msg_42065
Originally posted by: b_apolci.libero.it
The same just happened to me.
It seems that with the last update a new configuration appeared in the
preferences (Team->SVN->Diff Viewer) and the default values for the File
Associations tabs reflect a particular configuration (may be the one of
the developer) that requires TortoiseSVN.
I just unchecked the two file associtation active and the problem
disappeared.
Andrea
stuart mellanby ha scritto:
> I'm getting an error when trying to compare two versions of a file. I'm
> use the internal one.
> "External compare was failed. Cannot run program "C:/Program":
> CreateProcess error=2, The system cannot find the file specified"
> use the default eclipse compare editor?
> more info
> editor.
> org.eclipse.team.svn.core.operation.local.RunExternalCompare Operation$ExternalCompareOperationHelper.execute(RunExternal CompareOperation.java:218)
>]]>2009-02-25T10:00:25-00:00Re: external compare editor failed
https://www.eclipse.org/forums/index.php/mv/msg/13346/42718/#msg_42718
By mistake, build contained part of new functionality(related to external
compare editor). Please, update to latest version, it's fixed now
> disappeared.
> Andrea
>> more info
>> editor.
>>]]>Igor Burilo2009-02-27T15:15:18-00:00Re: external compare editor failed
https://www.eclipse.org/forums/index.php/mv/msg/13346/43174/#msg_43174
stuart mellanby2009-03-12T16:01:22-00:00
