Eclipse Community ForumsExpression - dateDifference method usage
https://www.eclipse.org/forums/index.php/mv/msg/126283/387775/#msg_387775
I am trying to use the class:
org.eclipse.persistence.expressions.Expression by invoking the
dateDifference method:
public Expression dateDifference(java.lang.String datePart,
Expression comparisonExpression).
However, when I tried to use it I got the following error
exception:SybSQLException: 'MOD_DATE' is not a recognized datediff option.
All that I am trying to do is to get the total seconds elapsed between two
datetime columns (in my case, its the modDate column) from a table called
DocStore. I've made sure from the JavaDoc API that I've put in the
correct parameters.
I've used the following statement:
responseRequestDateTimeDifferenceExpression =
I expected the SQL transformation to get something like:
DATEDIFF(second, responseDoc.MOD_DATE, requestDoc.MOD_DATE)
but that did not happen. I ran across the datediff error exception. Shown
below are further details of the code and error exception.
What am I doing wrong? Any advice or ideas are truly appreciated.
Thank you,
Ken Unpingco
Here is the java code:
addrProcessExpression = new ExpressionBuilder();
reportQuery = new ReportQuery(AddressProcess.class, addrProcessExpression);
requestResponseDateRangeExpression =
******** Details for the log on the exception
Exception [EclipseLink-4002] (Eclipse Persistence Services -
2.0.0.v20090424-r4050):
org.eclipse.persistence.exceptions.DatabaseException
Internal Exception: com.sybase.jdbc3.jdbc.SybSQLException: 'MOD_DATE' is
Error Code: 155
Call: SELECT SUM(DATEDIFF(t0.MOD_DATE, t3.MOD_DATE, t0.MOD_DATE)) FROM
DOCSTORE t3, ADDRESS_PROCESS t2, PROCESS t1, DOCSTORE t0 WHERE
((((((t0.MOD_DATE BETWEEN ? AND ?) AND (t3.MOD_DATE BETWEEN ? AND ?)) AND
NOT ((t2.RESPONSE_DOC_ID IS NULL))) AND NOT ((t2.REQUEST_DOC_ID IS NULL)))
AND ((t2.ID = t1.ID) AND (t1.discriminator = ?))) AND ((t0.ID =
t2.REQUEST_DOC_ID) AND (t3.ID = t2.RESPONSE_DOC_ID)))
bind => [2009-01-01 00:00:00.0, 2009-05-09 00:00:00.0, 2009-01-01
00:00:00.0, 2009-05-09 00:00:00.0, Address]
Query: ReportQuery(referenceClass=AddressProcess sql="SELECT
SUM(DATEDIFF(t0.MOD_DATE, t3.MOD_DATE, t0.MOD_DATE)) FROM DOCSTORE t3,
ADDRESS_PROCESS t2, PROCESS t1, DOCSTORE t0 WHERE ((((((t0.MOD_DATE
BETWEEN ? AND ?) AND (t3.MOD_DATE BETWEEN ? AND ?)) AND NOT
((t2.RESPONSE_DOC_ID IS NULL))) AND NOT ((t2.REQUEST_DOC_ID IS NULL))) AND
t2.REQUEST_DOC_ID) AND (t3.ID = t2.RESPONSE_DOC_ID)))")
root cause
com.sybase.jdbc3.jdbc.SybSQLException: 'MOD_DATE' is not a recognized
datediff option.]]>Kenneth Unpingco2009-05-09T00:43:21-00:00Re: Expression - dateDifference method usage
https://www.eclipse.org/forums/index.php/mv/msg/126283/387781/#msg_387781
correct. Are you sure you are executing the query you think you are?
James http://www.nabble.com/EclipseLink---Users-f26658.html]]>James Sutherland2009-05-11T13:46:55-00:00Re: Expression - dateDifference method usage
https://www.eclipse.org/forums/index.php/mv/msg/126283/387782/#msg_387782
I am very sure that I am executing the correct query. I am using Sybase
ASE 15.0 database (that has a DATEDIFF function). I too, agree with you
that I cannot see why this is not working when I seem to have the
Expression code that looks correct.
