Eclipse Community ForumsMain content navigation published page missing
https://www.eclipse.org/forums/index.php/mv/msg/11182/34747/#msg_34747
Originally posted by: bill.mcgirr.gmail.com
When I publish a site from the content that I am working on, the
navigation page associated with my view is not created. The page, which
takes on the view's name is normally created and placed in the noapplet
directory. About 50% of the time the file is not created. I have yet to
determine a set of reliable steps to reproduce or a set of workaround
steps. I have changed publishing settings, quit EPF, rebooted.
Eventually the page is produced and I can move on.
Without the page, the site obviously does not function. This is a fairly
critical error.]]>2007-07-09T16:51:50-00:00Re: Main content navigation published page missing
https://www.eclipse.org/forums/index.php/mv/msg/11182/580117/#msg_580117
Originally posted by: echchad.gmx.de
I don't know if it solves the problem but as i had a problem that was
quite similar to yours, well Imade an update of the java virtual machine
and this solved it. you can try it if you don't have already the latest
version.
BR
Abdelilah Echchad]]>2007-07-13T10:58:38-00:00Re: Main content navigation published page missing
https://www.eclipse.org/forums/index.php/mv/msg/11182/34984/#msg_34984
version.
BR
