Eclipse Community Forumsui not working?
https://www.eclipse.org/forums/index.php/mv/msg/1112964/1858941/#msg_1858941
i have no idea if adding the image worked so i'll also put the text of the message here-
"'Show Console View' has encountered a problem. An internal error has occurred"
then when i press "details" this comes up-"An internal error has occurred.
Cannot invoke "org.eclipse.ui.part.IPage.getControl()" because the return value of "org.eclipse.ui.part.PageBookView.getCurrentPage()" is null"
how can i make the console work so i can run and trial my code? i would really appreciate some help!
thankyou in advance :)]]>Nia Vaikla2023-05-02T14:47:42-00:00Re: ui not working?
https://www.eclipse.org/forums/index.php/mv/msg/1112964/1858943/#msg_1858943
Nitin Dahyabhai2023-05-02T15:28:33-00:00
