Eclipse Community ForumsFiles Extension (*.cpp) not added automatically by Eclipse IDE when they are created.
https://www.eclipse.org/forums/index.php/mv/msg/1109441/1847937/#msg_1847937
AHMED MOKHTAR2021-11-14T07:04:01-00:00Re: Files Extension (*.cpp) not added automatically by Eclipse IDE when they are created.
https://www.eclipse.org/forums/index.php/mv/msg/1109441/1847939/#msg_1847939
To the filename when created using File->New->Source File?
To the project when created using File->New->Source File?
To the project when created externally?
Something else?
Tell us what you've done and what you expected to happen.
]]>David Vavra2021-11-14T15:13:11-00:00Re: Files Extension (*.cpp) not added automatically by Eclipse IDE when they are created.
https://www.eclipse.org/forums/index.php/mv/msg/1109441/1847978/#msg_1847978
>After create C++ Project
> New > Source file.
> It create Text file but you have to append .cpp to make it C++ source file]]>AHMED MOKHTAR2021-11-16T02:15:37-00:00Re: Files Extension (*.cpp) not added automatically by Eclipse IDE when they are created.
https://www.eclipse.org/forums/index.php/mv/msg/1109441/1847979/#msg_1847979
.cpp isn't the only extent possible there's .cxx and .C for instance.
You can edit the templates but I'm not sure if you can edit the
filename with them.
