org.junit.jupiter.engine.execution.JupiterEngineExecutionContext close SEVERE: Caught exception while closing extension context: org.junit.jupiter.engine.descriptor.ClassExtensionContext@6f6a7463 com.google.inject.CreationException: Guice creation errors: 1) No implementation for mydsl.formatting2.MyBaseDslFormatter was bound. at org.eclipse.xtext.service.MethodBasedModule.configure(MethodBasedModule.java:58) 1 error at com.google.inject.internal.Errors.throwCreationExceptionIfErrorsExist(Errors.java:435) at com.google.inject.internal.InternalInjectorCreator.initializeStatically(InternalInjectorCreator.java:154) at com.google.inject.internal.InternalInjectorCreator.build(InternalInjectorCreator.java:106) at com.google.inject.Guice.createInjector(Guice.java:95) at com.google.inject.Guice.createInjector(Guice.java:72) at com.google.inject.Guice.createInjector(Guice.java:62) at mydsl.MyBaseDslStandaloneSetupGenerated.createInjector(MyBaseDslStandaloneSetupGenerated.java:29) at mydsl.MyBaseDslStandaloneSetupGenerated.createInjectorAndDoEMFRegistration(MyBaseDslStandaloneSetupGenerated.java:23) at mydsl.MyBaseDslStandaloneSetup.doSetup(MyBaseDslStandaloneSetup.java:13) at mydsl.MyExtendedDslStandaloneSetupGenerated.createInjectorAndDoEMFRegistration(MyExtendedDslStandaloneSetupGenerated.java:21) at mydsl.tests.MyExtendedDslInjectorProvider.internalCreateInjector(MyExtendedDslInjectorProvider.java:40) at mydsl.tests.MyExtendedDslInjectorProvider.getInjector(MyExtendedDslInjectorProvider.java:28) at mydsl.tests.MyExtendedDslInjectorProvider.setupRegistry(MyExtendedDslInjectorProvider.java:65) at org.eclipse.xtext.testing.extensions.InjectionExtension$RegistryReset.setup(InjectionExtension.java:71) at org.eclipse.xtext.testing.extensions.InjectionExtension$RegistryReset.<init>(InjectionExtension.java:65) at org.junit.jupiter.engine.execution.ExtensionValuesStore.lambda$getOrComputeIfAbsent$4(ExtensionValuesStore.java:86) at org.junit.jupiter.engine.execution.ExtensionValuesStore$MemoizingSupplier.get(ExtensionValuesStore.java:205) at org.junit.jupiter.engine.execution.ExtensionValuesStore$StoredValue.evaluate(ExtensionValuesStore.java:182) at org.junit.jupiter.engine.execution.ExtensionValuesStore$StoredValue.access$100(ExtensionValuesStore.java:171) at org.junit.jupiter.engine.execution.ExtensionValuesStore.lambda$closeAllStoredCloseableValues$1(ExtensionValuesStore.java:65) at java.base/java.util.stream.ReferencePipeline$2$1.accept(ReferencePipeline.java:176) at java.base/java.util.concurrent.ConcurrentHashMap$ValueSpliterator.forEachRemaining(ConcurrentHashMap.java:3605) at java.base/java.util.stream.AbstractPipeline.copyInto(AbstractPipeline.java:484) at java.base/java.util.stream.AbstractPipeline.wrapAndCopyInto(AbstractPipeline.java:474) at java.base/java.util.stream.ForEachOps$ForEachOp.evaluateSequential(ForEachOps.java:150) at java.base/java.util.stream.ForEachOps$ForEachOp$OfRef.evaluateSequential(ForEachOps.java:173) at java.base/java.util.stream.AbstractPipeline.evaluate(AbstractPipeline.java:234) at java.base/java.util.stream.ReferencePipeline.forEach(ReferencePipeline.java:497) at org.junit.jupiter.engine.execution.ExtensionValuesStore.closeAllStoredCloseableValues(ExtensionValuesStore.java:68) at org.junit.jupiter.engine.descriptor.AbstractExtensionContext.close(AbstractExtensionContext.java:74) at org.junit.jupiter.engine.execution.JupiterEngineExecutionContext.close(JupiterEngineExecutionContext.java:53) at org.junit.jupiter.engine.descriptor.JupiterTestDescriptor.cleanUp(JupiterTestDescriptor.java:222) at org.junit.jupiter.engine.descriptor.JupiterTestDescriptor.cleanUp(JupiterTestDescriptor.java:57) at org.junit.platform.engine.support.hierarchical.NodeTestTask.lambda$cleanUp$9(NodeTestTask.java:155) at org.junit.platform.engine.support.hierarchical.ThrowableCollector.execute(ThrowableCollector.java:73) at org.junit.platform.engine.support.hierarchical.NodeTestTask.cleanUp(NodeTestTask.java:155) at org.junit.platform.engine.support.hierarchical.NodeTestTask.execute(NodeTestTask.java:87) at java.base/java.util.ArrayList.forEach(ArrayList.java:1540) at org.junit.platform.engine.support.hierarchical.SameThreadHierarchicalTestExecutorService.invokeAll(SameThreadHierarchicalTestExecutorService.java:38) at org.junit.platform.engine.support.hierarchical.NodeTestTask.lambda$executeRecursively$5(NodeTestTask.java:143) at org.junit.platform.engine.support.hierarchical.ThrowableCollector.execute(ThrowableCollector.java:73) at org.junit.platform.engine.support.hierarchical.NodeTestTask.lambda$executeRecursively$7(NodeTestTask.java:129) at org.junit.platform.engine.support.hierarchical.Node.around(Node.java:137) at org.junit.platform.engine.support.hierarchical.NodeTestTask.lambda$executeRecursively$8(NodeTestTask.java:127) at org.junit.platform.engine.support.hierarchical.ThrowableCollector.execute(ThrowableCollector.java:73) at org.junit.platform.engine.support.hierarchical.NodeTestTask.executeRecursively(NodeTestTask.java:126) at org.junit.platform.engine.support.hierarchical.NodeTestTask.execute(NodeTestTask.java:84) at org.junit.platform.engine.support.hierarchical.SameThreadHierarchicalTestExecutorService.submit(SameThreadHierarchicalTestExecutorService.java:32) at org.junit.platform.engine.support.hierarchical.HierarchicalTestExecutor.execute(HierarchicalTestExecutor.java:57) at org.junit.platform.engine.support.hierarchical.HierarchicalTestEngine.execute(HierarchicalTestEngine.java:51) at org.junit.platform.launcher.core.EngineExecutionOrchestrator.execute(EngineExecutionOrchestrator.java:108) at org.junit.platform.launcher.core.EngineExecutionOrchestrator.execute(EngineExecutionOrchestrator.java:88) at org.junit.platform.launcher.core.EngineExecutionOrchestrator.lambda$execute$0(EngineExecutionOrchestrator.java:54) at org.junit.platform.launcher.core.EngineExecutionOrchestrator.withInterceptedStreams(EngineExecutionOrchestrator.java:67) at org.junit.platform.launcher.core.EngineExecutionOrchestrator.execute(EngineExecutionOrchestrator.java:52) at org.junit.platform.launcher.core.DefaultLauncher.execute(DefaultLauncher.java:96) at org.junit.platform.launcher.core.DefaultLauncher.execute(DefaultLauncher.java:84) at org.eclipse.jdt.internal.junit5.runner.JUnit5TestReference.run(JUnit5TestReference.java:98) at org.eclipse.jdt.internal.junit.runner.TestExecution.run(TestExecution.java:41) at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:542) at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:770) at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(RemoteTestRunner.java:464) at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.main(RemoteTestRunner.java:210)
how is the inheritance hierarchy of your modules
org.eclipse.xtext.service.AbstractGenericModule org.eclipse.xtext.service.DefaultRuntimeModule mydsl.AbstractMyBaseDslRuntimeModule mydsl.MyBaseDslRuntimeModule mydsl.AbstractMyExtendedDslRuntimeModule mydsl.MyExtendedDslRuntimeModule
org.eclipse.xtext.service.AbstractGenericModule org.eclipse.xtext.ide.DefaultIdeModule mydsl.ide.AbstractMyBaseDslIdeModule mydsl.ide.MyBaseDslIdeModule mydsl.ide.AbstractMyExtendedDslIdeModule mydsl.ide.MyExtendedDslIdeModule
org.eclipse.xtext.service.AbstractGenericModule org.eclipse.xtext.ui.DefaultUiModule mydsl.ui.AbstractMyBaseDslUiModule mydsl.ui.MyBaseDslUiModule mydsl.ui.AbstractMyExtendedDslUiModule mydsl.ui.MyExtendedDslUiModule
and where are bindings for the formatter and where not
mydsl.AbstractMyBaseDslRuntimeModule --> mydsl.formatting2.MyBaseDslFormatter mydsl.AbstractMyExtendedDslRuntimeModule --> mydsl.formatting2.MyExtendedDslFormatter mydsl.ide.AbstractMyBaseDslIdeModule --> no binding mydsl.ide.AbstractMyExtendedDslIdeModule --> no binding mydsl.ui.AbstractMyBaseDslUiModule --> no binding mydsl.ui.AbstractMyExtendedDslUiModule --> no binding
org.eclipse.xtext.formatting2.AbstractFormatter2 mydsl.formatting2.MyBaseDslFormatter mydsl.formatting2.MyExtendedDslFormatter
mydsl.ma.AbstractMyExtendedDslRuntimeModule
mydsl.ma.MyExtendedDslRuntimeModule
looks bogus.
how to the grammar look like inheritance wise?
grammar mydsl.MyBaseDsl with org.eclipse.xtext.common.Terminals import "http://www.eclipse.org/emf/2002/Ecore" as ecore generate base "http://foobar/Base"
grammar mydsl.MyExtendedDsl with mydsl.MyBaseDsl generate extended "http://foobar/Extended"
which injector provider do you use in test?
it looks like the runtime modules dont inherit from each other
