Eclipse Community ForumsError - Java Developement
https://www.eclipse.org/forums/index.php/mv/msg/1107220/1838892/#msg_1838892
Caused by: java.lang.ClassNotFoundException: program" The name of my class is program. I red here and found the solution to reopen Eclipse. That failed, my JVM was not up to date. I have Java Version 8 and JRE Version 1.8.281. I changed the JVM to my downloaded JDK 15 which I have manually downloaded. I could open Eclipse again but the errors still apears.
Oh, and I also changed the Eclipse encoding to UTF-8.
I would really appreciate if one of you guys could give me a tip how to solve it! Thanks <3
]]>Bella Jesse2021-03-08T11:27:34-00:00Re: Error - Java Developement
https://www.eclipse.org/forums/index.php/mv/msg/1107220/1838902/#msg_1838902
Errors are shown by error marker icons in the editor, and in the package or project explorer. By default, they show a white "x" in a red square. Check if there are any, and fix the errors indicated. Then try again.]]>Thomas Wolf2021-03-08T20:44:01-00:00
