Eclipse Community ForumsEclipse 2020-09 crashes repeatedly, errors with multiple plugins
https://www.eclipse.org/forums/index.php/mv/msg/1105341/1832718/#msg_1832718
]]>Andrew Norman2020-09-23T20:16:49-00:00Re: Eclipse 2020-09 crashes repeatedly, errors with multiple plugins
https://www.eclipse.org/forums/index.php/mv/msg/1105341/1832719/#msg_1832719
Andrew Norman2020-09-23T20:21:11-00:00Re: Eclipse 2020-09 crashes repeatedly, errors with multiple plugins
https://www.eclipse.org/forums/index.php/mv/msg/1105341/1832720/#msg_1832720
Andrew Norman2020-09-23T20:22:14-00:00Re: Eclipse 2020-09 crashes repeatedly, errors with multiple plugins
https://www.eclipse.org/forums/index.php/mv/msg/1105341/1832722/#msg_1832722
The Java postfix Template is also failing in the content assist as well as is the TemplateProposalComputer! ]]>Andrew Norman2020-09-23T20:29:00-00:00Re: Eclipse 2020-09 crashes repeatedly, errors with multiple plugins
https://www.eclipse.org/forums/index.php/mv/msg/1105341/1832724/#msg_1832724
Errors running builder 'Scala Builder' on project 'resolverservice'.
Unable to find Asm for stackmap generation (Looking for 'aj.org.objectweb.asm.ClassReader'). Stackmap generation for woven code is required to avoid verify errors on a Java 1.7 or higher runtime
when weaving type org.eclipse.jdt.internal.compiler.lookup.MethodVerifier
when weaving classes
when weaving
when weaving ]]>Andrew Norman2020-09-23T20:47:05-00:00Re: Eclipse 2020-09 crashes repeatedly, errors with multiple plugins
https://www.eclipse.org/forums/index.php/mv/msg/1105341/1832725/#msg_1832725
but you can try opening the About dialog, going into the Installation Details, and seeing
what you can do from the Update History.
Was there a reason you wrote 5 posts in the same thread replying to yourself? Posts are editable.]]>Nitin Dahyabhai2020-09-23T20:55:38-00:00Re: Eclipse 2020-09 crashes repeatedly, errors with multiple plugins
https://www.eclipse.org/forums/index.php/mv/msg/1105341/1832728/#msg_1832728
I've tried creating a new workspace -> doesn't work
I've tried downloading / installing a new Eclipse 2020-09 from scratch -> fewer errors but nothing compiles. Also I can only open scala classes using a text editor. (Both compiling and file opening) fail on the "required to avoid verify errors on a Java 1.7 or higher runtime when weaving type org.eclipse.jdt.core.search.SearchDocument when weaving classes when weaving" error :(
@DahyabhaiFriend, I stumbled into this when my eclipse 2020-06 auto updated to 2020-09. (I originally installed this as a 2018 install).
That said, installing 2020-09 on my Mac from a fresh download and a fresh workspace is not resolving all the issues and I'm still facing basic "IDE does not compile issues".
btw, I've been using Eclipse going back to 2001.]]>Andrew Norman2020-09-23T22:04:42-00:00Re: Eclipse 2020-09 crashes repeatedly, errors with multiple plugins
https://www.eclipse.org/forums/index.php/mv/msg/1105341/1832729/#msg_1832729
when I try to navigate to the eclipse/preferences/installed JREs settings I get another failure and the screen doesn't render
Errors running builder 'Scala Builder' on project 'sfsync-resolve'.
Unable to find Asm for stackmap generation (Looking for 'aj.org.objectweb.asm.ClassReader'). Stackmap generation for woven code is required to avoid verify errors on a Java 1.7 or higher runtime ]]>Andrew Norman2020-09-23T22:09:45-00:00Re: Eclipse 2020-09 crashes repeatedly, errors with multiple plugins
https://www.eclipse.org/forums/index.php/mv/msg/1105341/1832730/#msg_1832730
Nitin Dahyabhai2020-09-23T23:36:43-00:00Re: Eclipse 2020-09 crashes repeatedly, errors with multiple plugins
https://www.eclipse.org/forums/index.php/mv/msg/1105341/1832736/#msg_1832736
http://scala-ide.org/download/sdk.html
brings up an Oxygen version of Eclipse and that version definitely doesn't run with Java 11; it won't even start with Java 11. Their latest release appears to be 2.5 years old so it's not so surprising that it doesn't work with the latest version if Eclipse...
]]>Ed Merks2020-09-24T04:58:48-00:00Re: Eclipse 2020-09 crashes repeatedly, errors with multiple plugins
https://www.eclipse.org/forums/index.php/mv/msg/1105341/1832772/#msg_1832772
FWIW, scala has declared they aren't working on the eclipse IDE again until they have Scala 3 out. Scala 3 won't be released until after Scala 2.14 comes out.
#eclipseBrokeCompatibilityToAnEntireProgrammingLanguage]]>Andrew Norman2020-09-24T16:38:08-00:00Re: Eclipse 2020-09 crashes repeatedly, errors with multiple plugins
https://www.eclipse.org/forums/index.php/mv/msg/1105341/1832773/#msg_1832773
https://en.wikipedia.org/wiki/Java_version_history]]>Andrew Norman2020-09-24T16:58:45-00:00Re: Eclipse 2020-09 crashes repeatedly, errors with multiple plugins
https://www.eclipse.org/forums/index.php/mv/msg/1105341/1832779/#msg_1832779
Nitin Dahyabhai2020-09-24T21:11:45-00:00Re: Eclipse 2020-09 crashes repeatedly, errors with multiple plugins
https://www.eclipse.org/forums/index.php/mv/msg/1105341/1833693/#msg_1833693
Thanks to this post indicating that the using the installer with the bundled JDK worked:
stackoverflow.com/questions/64319086/eclipse-unable-to-find-asm
#EDIT 2020-10-28
I continued to get similar errors for other parts. I ended up using the installer to get the "bundled" jdk. That worked great for a few days and then I was back to getting ASM and weaving errors for various things including searches. I tried installing the "Eclipse Automated Error Reporting" feature to reporting these hard to reproduce errors but then I could no longer open JDK classes like DateTimeFormmatter even after reverting the install. For now, my only recourse seems to be going back my 2020-06 install and workspace. :(]]>Nathan Niesen2020-10-21T16:33:20-00:00
