Eclipse Community Forumse4 and error log view
https://www.eclipse.org/forums/index.php/mv/msg/1105012/1831683/#msg_1831683
I am writing an Eclipse RCP application since 2013.I still did not migrate to e4 and use Eclipse RCP 4.9 right now. Forgive me if this means I am already using e4 with some compatibility layer. I dealt with the Eclipse integration in the beginning and am now only adding functionality apart from the eclipse framework. So I have no deep knowledge about this.
I think about migrating to e4 from time to time as I don't use "too much" of eclipse itself (views, dialogs, error log, plug-in system and probably some more). However every time I start investigating this I end at the same point since years: There seems to be no error log view for pure e4. I always expect this is a pretty basic thing and that it should be available if I check a year later but I fail from year to year. Is there another solution? Or is there a similar functionality by another name?
I pop up error dialogs from time to time but some errors only go to the background and should be looked up by the user in the error log.
Best Regards,
Christian
]]>ChristianR Mising name2020-08-26T14:17:21-00:00Re: e4 and error log view
https://www.eclipse.org/forums/index.php/mv/msg/1105012/1831686/#msg_1831686
ChristianR Mising name2020-08-26T15:01:38-00:00Re: e4 and error log view
https://www.eclipse.org/forums/index.php/mv/msg/1105012/1831707/#msg_1831707
Eclipse SDK itself still heavily depends on E3 API and compatibility layers in E4. There is a relatively small team that works on Eclipse Platform, and within that team there are only a few that look into E4 related topics. There is currently no effort going on to try to migrate parts of Eclipse to the E4 APIs. However, Eclipse platform is happily accepting any help from the community. So if you are in need of this feature, and like to help the community as a whole forward, feel free to start working on a port to E4. This should be a will defined task, given that the error log view is relatively decoupled form the rest of the Platform.
So feel free to help and donate some time or money to help Eclipse further: https://www.eclipse.org/setups/donate/?scope=Eclipse%20SDK
]]>Rolf Theunissen2020-08-27T07:01:14-00:00Re: e4 and error log view
https://www.eclipse.org/forums/index.php/mv/msg/1105012/1831708/#msg_1831708
This topic discusses how you can use this layer in your own application: https://www.eclipse.org/forums/index.php/t/358552/]]>Rolf Theunissen2020-08-27T07:07:19-00:00Re: e4 and error log view
https://www.eclipse.org/forums/index.php/mv/msg/1105012/1832233/#msg_1832233
]]>ChristianR Mising name2020-09-13T10:35:04-00:00
