Eclipse Community ForumsType Export in 4diac 1.12.2
https://www.eclipse.org/forums/index.php/mv/msg/1103941/1827919/#msg_1827919
I just updated to 4diac 1.12.2 but was unable to open any of my previous applications. While they were opening, Eclipse told me that the workspace was incompatible.
Since the application was easy to re-create I did so and brought in copies of my SIFB's into the new application. They all re-exported fine but one based on a simple Basic Function Block would not export (image is attached separately)
Did I do something wrong during the upgrade? I'll try to re-create this BFB from scratch and see if it exports this time.
Thanks for your help.]]>Barry Dowdeswell2020-05-27T00:53:25-00:00Re: Type Export in 4diac 1.12.2
https://www.eclipse.org/forums/index.php/mv/msg/1103941/1827920/#msg_1827920
Errors
- F_TO_C_CONV class org.eclipse.fordiac.ide.model.libraryElement.impl.SimpleFBTypeImpl cannot be cast to class org.eclipse.fordiac.ide.model.libraryElement.BasicFBType (org.eclipse.fordiac.ide.model.libraryElement.impl.SimpleFBTypeImpl and org.eclipse.fordiac.ide.model.libraryElement.BasicFBType are in unnamed module of loader org.eclipse.osgi.internal.loader.EquinoxClassLoader @7e28f150) (F_TO_C_CONV.fbt)
]]>Barry Dowdeswell2020-05-27T01:06:44-00:00Re: Type Export in 4diac 1.12.2
https://www.eclipse.org/forums/index.php/mv/msg/1103941/1827934/#msg_1827934
first of all: Please separate your projects from your workspace. Workspace settings may change between 4diac IDE versions. Projects can always be imported. Please use File -> Import -> existing projects into workspace.
With that you can preserve your projects across 4diac versions.
Regarding your export problem. could you be so kind and write a bug report on it. May I have your FB for testing?]]>Alois Zoitl2020-05-27T08:10:16-00:00Re: Type Export in 4diac 1.12.2
https://www.eclipse.org/forums/index.php/mv/msg/1103941/1827966/#msg_1827966
I appreciate your help. I will perform a clean update on a restored OS image I made before the upgrade and then import the projects as you suggest. I suspect the problem with the export is related since I was able to recreate the F_TO_C_CONV from scratch and export it perfectly.
Badger
]]>Barry Dowdeswell2020-05-27T20:13:04-00:00Re: Type Export in 4diac 1.12.2
https://www.eclipse.org/forums/index.php/mv/msg/1103941/1827967/#msg_1827967
Alois Zoitl2020-05-27T20:29:09-00:00Re: Type Export in 4diac 1.12.2
https://www.eclipse.org/forums/index.php/mv/msg/1103941/1828168/#msg_1828168
I am running Ubuntu 18.10 and I was unable to do an upgrade to 1.12.2 from inside 4diac. Hence I performed a clean install of 1.12.2. I created a new workspace, a new HVAC project and then imported the archive file HVAC.zip. That produced a few problems since it created an extra HVAC folder deeper into the project rather than bringing it in to the root of the project as expected. However, after moving the files manually, it worked fine.
All the existing function blocks then exported this time fine except the F_TO_C_CONV. It produced the same error as before. Very strange..
I think the earlier error was related to not upgrading the workspace properly to the new format - I should have used the archive function - my mistake. I have some work to do on this block over the next few days so I suggest we close this issue and I will work further to see why that block is different. I do not think it is related to the new version of 4diac.
Thank you for all your assistance.
]]>Barry Dowdeswell2020-06-03T08:21:44-00:00Re: Type Export in 4diac 1.12.2
https://www.eclipse.org/forums/index.php/mv/msg/1103941/1828188/#msg_1828188
thanks for the information and your assessment. I hope you can sort out your issue. I would still be interested in your Fb especially as for the upcoming 1.13.0 version of 4diac IDE we are replacing the code generator and strange FBs would be good testcases for the new infrastructure. But I leave it to you to decide if it makes sense or not.]]>Alois Zoitl2020-06-03T12:42:41-00:00
