Eclipse Community ForumsProblem to instantiate objects of a specific type from another of the same type
https://www.eclipse.org/forums/index.php/mv/msg/1103804/1827523/#msg_1827523
You can see my metamodel in attachments, the problem is to create a new object of type "Node" from the Node object already created from "Authentifier". As we can see in nodeProperties.png, objects are successfully created and connected to the first Node object, but nothing appears on the diagram. So I can't even change the name of each Node object, and I can't connect them to any other objects. Do someone know how can I make them appear on the diagram ? The three other screenshots show you how I did to create a node Node.
Léo
]]>Léo Cauvin2020-05-17T09:35:06-00:00Re: Problem to instantiate objects of a specific type from another of the same type
https://www.eclipse.org/forums/index.php/mv/msg/1103804/1827544/#msg_1827544
Avi Shaked2020-05-18T05:42:47-00:00Re: Problem to instantiate objects of a specific type from another of the same type
https://www.eclipse.org/forums/index.php/mv/msg/1103804/1827560/#msg_1827560
Here is the representation of my Node (very simple), nothing in other tabs, and nothing special except a feature:name as label in the Square light_orange properties. But I don't think this is the problem here because one objet Node is correctly created on the diagram (the one from Authentifier).
Could it come from the relation between an object Node and itself ?
Thanks for your answer.]]>Léo Cauvin2020-05-18T09:32:51-00:00Re: Problem to instantiate objects of a specific type from another of the same type
https://www.eclipse.org/forums/index.php/mv/msg/1103804/1827570/#msg_1827570
Avi Shaked2020-05-18T13:58:32-00:00Re: Problem to instantiate objects of a specific type from another of the same type
https://www.eclipse.org/forums/index.php/mv/msg/1103804/1827579/#msg_1827579
Thank you again Avi !]]>Léo Cauvin2020-05-18T16:35:08-00:00Re: Problem to instantiate objects of a specific type from another of the same type
https://www.eclipse.org/forums/index.php/mv/msg/1103804/1827583/#msg_1827583
Avi Shaked2020-05-18T17:07:54-00:00
