Eclipse Community ForumsError installation eclipse with java 13
https://www.eclipse.org/forums/index.php/mv/msg/1102361/1821312/#msg_1821312
I'm new in this forum and with eclipse environment; When trying to install Eclipse Oxygen after installing java; during the first run after clicking on Launch I see a message report: "An error has occurred. See the log file.."
I attached the log file below, could someone please help me to install eclipse CDT and find a solution;
Thanks in advance;
Chourouk.
]]>Chourouk NAIT SAIDI2020-02-10T17:55:03-00:00Re: Error installation eclipse with java 13
https://www.eclipse.org/forums/index.php/mv/msg/1102361/1821316/#msg_1821316
how you have a 4.7.3 maintenance build from 2018, but it falls under the same recommendations as with Java 9: https://www.eclipse.org/forums/index.php/t/198527/ .
Short answer: run Eclipse with Java 8 or use a version of Eclipse that's more closely concurrent with your release of Java.]]>Nitin Dahyabhai2020-02-10T18:24:37-00:00Re: Error installation eclipse with java 13
https://www.eclipse.org/forums/index.php/mv/msg/1102361/1821318/#msg_1821318
Chourouk NAIT SAIDI2020-02-10T18:28:05-00:00
